Passenger Side Mirror Not Working When Reversing
02 CLK 430
All,
My passenger side mirror doesn't point down when I place the car in reverse. Has anyone had that problem before? If so, how did you fix it?
Thanks,
Thanks,
2000 CLK 430 Conv.
I have related problem, mine does point down when I am backing up, but when I go forward, it is suppoed to go back to it original position.
It starts to go back and half way there, it gets stuck and I have to manually re-adjust the mirror.
Anybody else has the same problem or know how to fix it?
thanks
thanks
thanks
thanks
2000 CLK 320
Yeah, same problem for me. Happened before while car was in warranty and they fixed it. Then the problem recurred after the warranty so Ive been ignoring it. I have a feeling its some sort of circuit board that needs replacing, perhaps resetting.
I had the same probem. (Not returning to preset position when going to drive)
You can set where the mirror goes to when you put it in reverse (its in the manual somewhere!). After I did that that it started to go back to the correct position when putting the car in drive.
It's worth a try.
It's worth a try.
