Suspension Advice
The story so far:
I bought Eibach springs (for lowest drop) and Koni shocks for their adjustability.
The springs are supposed to drop 1 – 1.2 inches (I wanted max one inch).
The spring pads in front were #5 and #4 in back. To find out what you have you have to reach under the car and feel the pads (in the top of the suspension assembly) run your fingers around and you will find some raised dimples, count them and that is the pad you have.
I decided to leave the pads alone (to increase drop put in a lower pad #, #5 is the thickest pad you can get). I hoped to get an even drop of say 1 inch by leaving in the original pads.
The actual drop was 0.6 inches in back (Great!) and 0.1 in front (not so good) I am going to drive it a while to make sure everything settles but I will probably swap out the pads in front for #3 to gain about 0.6 inches of drop in front. The fender gaps are uneven now and I want them to match.
I set the shocks at the softest setting and the car rides well, I might increase them one stop some day but that means taking everything apart again! Stiffness is on par with my 2004 325i BMW with the sports package so I am happy since the CLK320 is my daily driver, and I want a comfortable ride.
I did not do the install!
Here is some info on Spring Pads:
Pad sizes are: 5, 9, 13, 17, and 21 mm, designated by the part number #'s by numbering them 1 (thinnest), 2, 3, 4, and 5 (thickest) the third group of numbers 01, 02 etc.
Front:
210-321-01-84 5mm
210-321-02-84 9mm
210-321-03-84 13mm
210-321-04-84 17mm
210-321-05-84 21mm
Rear:
210-325-01-84 5mm
210-325-02-84 9mm
210-325-03-84 13mm
210-325-04-84 17mm
210-325-05-84 21mm
Remember the car will drop more than the difference in spring pad thickness (the pads are closer to the pivot than the wheel).
