Garage door remote....
Old Feb 1, 2011 | 10:54 PM
bbrain's Avatar
1999 Civic Hatchback, 2002 c240, 2003 CLK 500
bringing this back because i just used this method for my w209 i recently bought! thanks
Originally Posted by mmgrad
given that a new MB was just added to the stable... the garage door opener needed to be syncronized
sync-ing with the 'learn' button on the motor will not work.
as many of you have complained about not being able to program with a rolling code opener, try using this procedure:
1.) reset the car's buttons:
- hold the far left and far right buttons at the same time for a few seconds (i think you need to wait until you see some light flash)
2.) remote-sync buttons
- use an already programmed remote control garage door opener to sync a button in the car... the light at the mirror should blink, release buttons when the light starts flashing fast
3.) sync with motor
- now, press the learn button on the motor, then press the same button you remote-sync-ed (the learn indicator on the motor should stop blinking, but will stay lit), press the same button again and that light should go off entirely
WHOA-LA.... it is now programmed. or at least i hope it should.
GOOD LUCK!!!
