How to adjust CLK conv. drivers window?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jun 11, 2006 | 05:09 PM
atikovi's Avatar
1995 S280 5-speed
The driver’s side front window on my ’01 CLK430 convertible sticks out too far from the A-pillar and top weather strips.
Besides rain getting in, there is annoying wind noise. Is there some adjustment for the glass I can make? If I press on the top of the glass while closing the door from the outside I can get it to seat properly before the window shuts all the way.
Old Sep 11, 2006 | 02:25 PM
numba41's Avatar
CLK 320, C32 AMG
I'm having the same exact problem with my 99 convertible. Is this just a design flaw and no one has a solution?
Old Sep 11, 2006 | 04:37 PM
Whodat's Avatar
2000 CLK 430 Cabriolet
I have a 2000 430 and sometimes my passenger window doesn't seat properly. my moms was in the car with me one time and the passenger window had that familiar whistling sound (highway speeds). She asked me to roll up the window. Since it was already all the way up, I rolled the window down half-way and rolled it back up and it seated properly, whistling sound was gone.
That being said, you probably need to figure out WHEN this is happening.
1) Are you already in the car, roll the window down and roll it back up?
(if so, there may be something going on with the weatherstripping on the rear window)
2) Does it happen only after you've put the top back up? (if so, your weatherstripping on the soft top may be warped.)
Your pictures didn't come thru on this site. Can you re-post em?
Old Sep 20, 2006 | 02:54 PM
JOHNNYRENO's Avatar
not seating door
did anyone get any info on this subject cause my 2000 clk 320 is doing it also
Old Sep 20, 2006 | 02:58 PM
JOHNNYRENO's Avatar
hee hee
bump
Old Sep 20, 2006 | 03:20 PM
atikovi's Avatar
1995 S280 5-speed
I sold the car before finding a fix.
Old Sep 20, 2006 | 07:38 PM
JOHNNYRENO's Avatar
THX fer the reply bro.
Old Dec 19, 2006 | 02:43 PM
numba41's Avatar
CLK 320, C32 AMG
Found this in another post but haven't tried it yet:
I'm new to this, but thought I might be able to help. My 1998 CLK320 had the same problem with the windows rolling up too high. When the door was shut, it would catch on the rubber strip at the top, and leave a gap down the side of the window. I phoned the stealer, and they advised that an adjustment would be about £120! What I found out is that if you open the door, roll down the window to the bottom, and then lie down underneath the door you will see some rubber plugs. Take these out, and then look up inside these holes, and you will see some star shaped bolts. These are the stops for the window regulator, and are adjustable. You will need a female Torx socket of the appropriate size. To make the window stop a little lower, turn the two adjusters (front and rear of window) a quarter of a turn clockwise each (or more as required), and then check the alignment. Ajust them up or down as appropriate, and check the alignment by winding up the window and shutting the door. Don't forget those seals do need to keep the weather out! When you have got the adjustment right, replace the rubber plugs, and then sit in the car, and wind the windows up by holding the switch at the first position (not one touch up), then hold in the 1st position for about 5 seconds. They should then function correctly, and you shouldn't have to slam the doors!!! It worked on mine!
Hope this helps.
Old Dec 19, 2006 | 03:04 PM
Silverbillet's Avatar
2001 CLK430 Cab; 2008 GL550
Numba, nice writeup. Thanks for the info.
Old Dec 21, 2006 | 11:00 AM
numba41's Avatar
CLK 320, C32 AMG
I can't take any credit for this, I just found it from another post.
Old Jun 5, 2010 | 01:36 PM
aqua190's Avatar
11 E550 Conv
this was a huge help with the front window, does anyone know the procedure for adjusting the rear window on the cabrio? mine seems to go up too high.
Old Jun 6, 2010 | 11:52 AM
Bigdaddy69's Avatar
2000 clk430
My passenger window has the same problem. I just roll the window down 1/4 inch until the door is closed then roll it back up. This worked for me.
Old Jun 8, 2010 | 09:34 PM
v8benzer's Avatar
2000 CLK430 COUPE
Thanks numba41! Couldn't find my T-30 TORX socket so i used a 3/16 inch 6-point socket, 1/2 turn clockwise on each screw did the trick. No more door slamming.
Old Jun 8, 2010 | 11:12 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
i got same prob on my cabrio in the rear.. seems too high
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
