key problems
Old Jul 25, 2006 | 05:29 AM
platinumney's Avatar
clk 320 pioneer FB 90 Chrome Halo projector headlights
key problems
I was wondering if the key runs on batteries if so how do I go about changing it
Old Jul 25, 2006 | 10:41 AM
DemonaL's Avatar
2008 BMW 535i, 2007 335i, 2003 E320, 2007 Hayabusa
The key charges in the ignition...
Old Jul 25, 2006 | 02:21 PM
CurYousGee's Avatar
2000 CLK 430
pull out the valet key, jam it into the side of the key in the near the butt, u can see a white tab that is holding the back end of the key, use the valet key to depress it and then pull the whole back end out, change ur batteries and ur done....do a search on the boards for pics
Old Jul 25, 2006 | 09:54 PM
CLKonDUBS's Avatar
Piece of SH*T
If the ignition charges the battery then why do I have to change my battery every 2-3 months and I rarely drive my *****? Also theres another member who can't even hold the power in his key for no more than 2 weeks! I don't think your info is correct...
Old Jul 26, 2006 | 11:30 AM
Whodat's Avatar
2000 CLK 430 Cabriolet
There is probably a voltage leak within the key fob. Does the battery in another key fob get drained as quickly? Does somebody have a second fob to test with because if it's only one key fob doing it, the problem lies within the fob.
GOOD LUCK!
Old Jul 26, 2006 | 08:48 PM
DemonaL's Avatar
hrmm, my benz is a 2000 model, and i havnt changed both my keys ONCE, the other key, I BARELY use, no problems, i just got a key 2 yrs ago, b/c i needed a spare, no problems, somethings wrong on your side.
Old Jul 26, 2006 | 11:40 PM
str8ridin's Avatar
05 E55
No offense dude, but give out information that you know to be true, not that you guess is true.
Old Jul 27, 2006 | 08:01 PM
JJB622's Avatar
1999 CLK320
I am not sure if the battery has ever been changed on my my CLK's key as I have only owned it for 6 months. What I have noticed is that the range is really weak, like maybe 15-20 feet. Any idea if changing the battery will solve this? Thanks.
Old Jul 27, 2006 | 08:37 PM
str8ridin's Avatar
05 E55
15-20 feet? That's good for our cars. Get a new battery...they are not too expensive and will help if you do have a weak battery. But they range isn't all that good period.
One thing I noticed was that when my range was getting bad and the IR stopped working completely (opening the windows etc. via the remote), it was not the key battery, but the car battery that was low on juice. After getting a new battery, it fixed everything.
