another wheel question... :)
I purchased a set of 18" replicas for my CLK (320) off craigslist because I needed some summer tires (putting winter on the stockers, but whatever
). The things are 18x7.5, 35 offset with 225/40 brand new rubber on them.I got the shorter bolts and all and mounted them, but they're a little wobbly at highway speeds. I got them balanced and checked for bends but they "seem" ok. I think the problem is in the front, since I can put rings in the rear to make sure they're centered on the hub, but they wouldn't fit in the front with rings -- at least not the same size.
Question is... I obviously need rings in the front, right? Or some kind of spacer to make sure they sit right on the hub and not off-center. What/where can I get and how fast can I get it?
Thanks x 3billion!
Thanks x 3billion!
Now I just gotta figure out what the correct spacer would be for my car and my wheels. The set is not staggered, so I'd probably have to get front and back, right? And I suppose it doesn't matter the size since I only need them to make sure the wheels are centered properly... so 5mm would work fine?
What size is the centerpiece? ( i think it's called the hub?)
From the evosport offerings, it looks like the safest bet is their 5mm (10mm total track) kit... http://evosport.com/product/proddeta...HL.SPC.512.610
Unless I'm completely off with what I'm trying to do here...
I just got an email back from mike @ evosport, so I'm gonna follow up on that. I'll measure the center bore of the wheel and the lugs that I have and see what I need. I have the loooong OEM hubs that came with the stock 16s, and the shorter ones that came with the aftermarket wheels, but I think the spacers would require something in between.
I guess we'll see. Thanks...
Hey, I just went through an ordeal of finding the right bolts and etc...so just to help you out...here's an informative post
http://www.benzworld.org/forums/w208...lt-length.html
I got my spacers from purems.com, and bolts from otisincla.com
You're gonna want to make sure if your rims need cone seating or ball seating.
I wish there was a simple javascript form or something where you could select the chassis, wheel offset, spacer size and hit a button and BAM... you get a shopping list.
Man that would make things so much easier.
