Mushy Brakes
I was told by the Mercedes dealer that mushy brakes are typical for this car. Since I wasn't able to drive another CLK to compare, I really couldn't argue that point, and since the brakes "worked" (that is, the car eventually does slow down and stop), I figured I would learn to live with it.
So do all CLK's have a mushy brake pedal? Pumping the pedal doesn't make any difference, so there doesn't seem to be a problem with air in the lines. Could there be a problem with the master cylinder or the boost assist? If this is just typical, what have others done to improve the brake pedal feel?
What front tires do you have on the different cars and what brake pads are on each?
