Problems with instrument panel
Old Aug 30, 2006 | 11:24 AM
deviltrick's Avatar
2002 CLK320, 2006 4.8is X5
Hi all,
Lately my instrument panel has some pixels on the outside temp. monitor and on the gear indicator that randomly go off. At first I thought it was because high temperatures and leaving the car parked under direct sunlight (it used to happen to a beetle I had with temp. monitor near the sunroof), but its been quite hot and returns to normal. Its acting randomly. Everything measures correctly, though.
Would it be advisable to change the cluster, or just clean it with compressed air? Is it easy to dismount the cluster?
Old Sep 1, 2006 | 03:42 PM
Serndipity's Avatar
2001 CLK320 Cabrio
If you do a search on on mbforums and/or http://www.mercedesshop.com/shopforu...isplay.php?f=1 you will find this is a common problem and can be fixed in several ways.
The cluster pulls out and you can buy or make a simple tool to do that.
Then you can:
Buy a new unit from MB (big bucks).
Have it rebuilt (upu'll find the place that does that for a couple of hundred $ in your search).
If you know now, you can find the faulty cold solder joint and re-solder it.
Old Sep 19, 2006 | 02:42 PM
deviltrick's Avatar
Thanks,
I think I'll go to any guy who fixes stereos with a multimeter and try to find the fault.
I'll let you know if I was succesfull or not
Old Sep 19, 2006 | 08:43 PM
lowphat's Avatar
01 LORINSER CLK 430 - 02 KLEEMANN CLK55 - 88 Euro / Jap AMG 560 SEC Widebody - 16 AMG GTS
Deviltrick - if you are still under warranty, get it fixed by the dealer - they'll replace the entire cluster for you.
Old Sep 20, 2006 | 11:47 AM
deviltrick's Avatar
No, warranty down here is 2 years with unlimited mileage... that happened quite a long time ago, and my car has only 20,000 miles.
Guess I'll try to fix it and if that doesn't work, look for one on ebay.
