Wheel bolts, Carlsson guys (?) help....
Old Aug 29, 2002 | 12:29 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I mention this here because maybe you CLK guys aren't using the track widener kit/spacers. A customer traded a W210 E class to me with some 19" Carlsson 1/6. Very nice looking setup, but when I took the rears apart for tires/balancing, I noticed that he was using the track widener kit (spacers). But he's been using the regular bolts, and only about 2 or 3 threads are catching. Yikes! Do you guys know the correct dimensions of the bolt for the spacer setup, or does someone have 10 of those bolts from your wheel set that I could buy/beg/borrow/steal from you? Would the bolts mentioned in the thread below (Spacers) from Autoclass be the correct ones? I wonder if Tirerack has them....thanks in advance for your help...allen.
Old Sep 7, 2002 | 02:12 AM
linh's Avatar
99' SLK 230 & 01' CLK 430
Yes, just call up Gaston.
