245's all the way around
Old Oct 3, 2006 | 03:02 PM
deuxslow's Avatar
W215
On my clk430 is it bad to run 245's on the front and rear? It has the staggert setup. We took it in for an oil change and the dealer commented that the car had the wrong size tires up front. Even the tire shop made a big deal about it.
Old Oct 3, 2006 | 04:32 PM
CLK A's Avatar
I had the same problem before with 19" wheels they won't work!
Old Oct 3, 2006 | 11:07 PM
clkal's Avatar
01' CLK55
well, what size wheels do you have?
Also, keep in mind that you have a rear-wheel-drive car. The stock set-up is already staggered, so unless you want to be EXTRA ECONOMICAL, you don't want to put the same sized tires front and rear.
Old Oct 4, 2006 | 12:55 PM
deuxslow's Avatar
W215
Yeah I understand all that. Aren't the stock tires are supposed to be 235/40 up front and 245/40 in the back? I guess what I'm asking is why is it a big deal to run 245s all around?
Old Oct 4, 2006 | 03:03 PM
clkal's Avatar
01' CLK55
i believe the stock set up is 225 front and 245 rear. Even when I went with a 19" staggered set up, I kept it 235/35/19 front and 265/30/19 rear. You don't have much room up front to accomodate a 245 very easily.
