Clock Display Outage
Old Oct 24, 2006 | 05:42 PM
MMM430's Avatar
'00 CLK430 & '08 Lexus RX 350
OK my clock display is starting to loose parts of the numbers.....the other day the temp on other side was doing the same. Hasnt happened again though. Will the temp and clock eventually go out all together? Will the main display be next?
Is there a quick fix or a full replacement?
Old Oct 24, 2006 | 06:31 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
Unfortunately it means you'll have to replace it since the individual pixels can't be replaced. Such simple dot matrix technology and Mercedes or their subcontractors can't get it right! Reminds me of something Chris Rock said once.........they got metal on the space shuttle that can go around the moon
and withstand temperatures of up to thousands of degrees and you you mean to tell me you don't think they can make an Eldorado where the *******g bumper don't fall off?
Old Oct 24, 2006 | 06:50 PM
Co 55 AMG's Avatar
W208
Old Oct 24, 2006 | 07:34 PM
MMM430's Avatar
thats pretty damn funny.
So how much is this gonna cost me?
Old Oct 24, 2006 | 10:07 PM
bbearden's Avatar
Might want to look on eBay for one. They have had alot in the past but be cautious b/c a number of them may have the same pixel issue. Maybe Steve from MBenzNL has some since he does the steering wheel retrofit that requires the gauge cluster. Look him up at http://mbenznl.com/
Old Oct 24, 2006 | 10:13 PM
MMM430's Avatar
Thanks bbearden
Good Idea. Will email steve. Thx
Old Oct 25, 2006 | 12:17 AM
drmaster's Avatar
02 CLK 320
I have a same problem here. Only with clock display for me.
Would you be kind enough to let me know what Steve says?
Old Oct 25, 2006 | 11:15 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Do a search and you will find a company here in MA that can repair it....recall that they charge $200 to $300.
Mine has had the digits going off and on for a year now. I believe it's poor solder connection where the connector fastens. I plan to pull the cluster (easy to do) and re-solder the connections.
Old Oct 25, 2006 | 12:35 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Here is the information regarding the company that can repair the pixel problem on instrument cluster.
BBA Remanufacturing Inc.
6 McCabe Street
South Darmouth, MA 02748
(866) 573-2740
www.bba-reman.com
Old Oct 25, 2006 | 03:38 PM
MMM430's Avatar
Beautiful....
Thanks for the insight.
Old Oct 26, 2006 | 07:57 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Tale of a another CLK owner.
http://www.mercedesshop.com/shopforu...d.php?t=168533
FYI....MB has recently recalled 220/C215 instrument clusters.
However, don't expect a recall on W208s (recalls are usually for safey reasons....the 220/C215 went totally dark and one could not see their speed etc. at night). MB doesn't care if you don't know the time and/or temperature.
Not going to get into a long post here...but, have been very disappointed in my ownership experience (e.g. reliabilty and specially dealer service) with the two MBs I've owned. Really did not how good I had it with my BMW and Infinity.
Old Oct 28, 2006 | 01:03 PM
deviltrick's Avatar
2002 CLK320, 2006 4.8is X5
In this thread https://mbworld.org/forums/clk-class-w208/168335-lot-s-manuals-208-others.html you'll find a post where it says the cluster overheats. It says that replacinf three bulbs could solve the problem.
I have the same problem with my clock, and still planning on re-soldering. I'll let you know it I'm succesful.
Old Oct 28, 2006 | 07:47 PM
The Jury's Avatar
2002 c240
yeah here's the TSB.
Indeed the unit DOES overheat according to my infrared heat gun.
Old Oct 29, 2006 | 03:24 PM
MMM430's Avatar
Great Info
Thanks guys!
Old Oct 29, 2006 | 09:20 PM
software's Avatar
2014 E550 Convertible
Thanks Jury!
This happens every time I take a trip.
(Scheisse auto!!) It looks like an easy fix.
Old Nov 4, 2006 | 02:31 AM
Whodat's Avatar
2000 CLK 430 Cabriolet
Ha! A failing CPS IS a SERIOUS safety issue but they still haven't recalled the 208 for that (the car cuts off...anywhere...after the car is warm/hot). So apparently they don't care if you're rear-ended when your car stops in the middle of the road either.
I feel you on the 'experience'. It is rather daunting. But what I've found out is a LOT of repairs are fairly simple and really don't cost much (if you can DIY), even though these problems should NOT be happening on cars of this magnitude, especially electrical problems.
Old Nov 4, 2006 | 03:13 AM
gregory13lil's Avatar
2000 CLK430
I am located in Germany and looked for a place to repair our instrument cluster pixel problem because mine is going out now.
I found a really good place for 125 bucks!!! He is 3 hours away from where I live.
This is his website:
http://pixelfehler-behebung.de/hauptseite.htm
He is looking into getting me a white AMG Gauge for my 2000 CLK430 with the miles and kilometers US Spec. I will get mine done next week so I will keep you guys poseted on how that goes.
Old Nov 4, 2006 | 03:48 AM
The Jury's Avatar
2002 c240
If it didn't have electrical problems it wouldn't be German.
Old Nov 4, 2006 | 07:57 AM
ThrillKill's Avatar
CLK/ML
Just had a cluster replaced on the ML. As much as I hate the stealer, they need to program it so you have little choice. With diagnosis it cost just shy of $900. Goddamn crooks.
Old Nov 6, 2006 | 11:31 AM
Whodat's Avatar
Ouch TK. I thought you would have tried to do that one yourself.
Old Nov 28, 2006 | 02:01 AM
drmaster's Avatar
02 CLK 320
Originally Posted by deviltrick
In this thread https://mbworld.org/forums/showthread.php?t=168335 you'll find a post where it says the cluster overheats. It says that replacinf three bulbs could solve the problem.
Did you able to fix it?
I am wondering how do you replace this three bulbs?
Is it easy to pull cluster?
Old Nov 28, 2006 | 11:57 AM
deviltrick's Avatar
Pulling out the cluster is really easy. I posted a DIY here: https://mbworld.org/forums/showthrea...77#post1827177
I did pull out the cluster, but in my case it wasn't the bulbs. Seems I have a bad solder connection, which has to be re-soldered.
Fixing it has a cost around $250, but need to remove the cluster and leave the car parked during repair.
Old Apr 10, 2007 | 10:39 PM
oneofayykind's Avatar
01 CLK 320 Cabriolet
Where can I get the new bulbs for this? Anyone have any idea?
Old Apr 12, 2007 | 05:10 AM
drmaster's Avatar
02 CLK 320
http://www.autohausaz.com/search/pro...r=000000000977
Old Apr 12, 2007 | 09:41 AM
Thanks for the help
