How do I get this big plastic cover off of my engine so that I can change the plugs ?
Old 03-26-2007 | 01:29 AM
Pancho's Avatar
2000 CLK430 Cabriolet
Re.: 2000 430 CLK Cabriolet
How do I get this big plastic cover off of my engine so that I can change the plugs ? I don't want to break it.
Link:
http://www.panchogun.com/FVWebPhotos...stic-Cover.jpg
Old 03-26-2007 | 01:31 AM
Silverbillet's Avatar
2001 CLK430 Cab; 2008 GL550
Just pull upward. You might it a hard tug.
Old 03-26-2007 | 01:37 AM
Amir_AMG's Avatar
Veteran: Air Force
2007 SL55
i believe there are 4 clips one on each corner just lift they will come off easily...
Old 03-26-2007 | 02:30 AM
gregory13lil's Avatar
2000 CLK430
Take the front 2 air tubes off of the intake and then pull upwards on the front of it to get the front off the clips. Then pull from the back area and the clips will come off. The last part should be where it connects to the MAF so you might have to wiggle it a little bit on the way out cause its a tight space when taking it out. But its only held on by 4 clips so dont worry about breaking it or something.
Greg
Old 03-26-2007 | 09:03 AM
deyainrdy4ds's Avatar
w208
yUp..just pull...u might need to use some force..
Quick Reply: How do I get this big plastic cover off of my engine so that I can change the plugs ?
