19" ADR M-Classics -- Need HELP!!
Old Apr 18, 2007 | 11:57 AM
murdock's Avatar
clk 320
I recently mounted a set of 19x8.5 front and 19x9.5 rear ADR M-Classics on my 1999 CLK Cabrio. The rear wheel was hubcentric, but the front was not.
Does anybody know the diameter of the front wheel hub (centerbore)?
Also, I was able to use the rear center caps, but could not use the fronts because the axle dust cap (covers the nut and holds in the grease) is in the way. Has anybody had this issue? If so, what was the solution?
Thanks in advance for your help.
Old Apr 18, 2007 | 07:08 PM
derek m's Avatar
02 CLK55, 07 E92 335 ProCede
any luck? maybe a spacer will work?
Old Apr 18, 2007 | 08:08 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
i had this same problem...i just kinda hammered in the dust cap a little and it was able to fit...ive had them like this since i got the rims about 6 months ago and have had no problems since...
Old Apr 18, 2007 | 10:28 PM
derek m's Avatar
any pics of your car and rims?
Old Apr 18, 2007 | 11:19 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
yea look through the pictures on these forums...
Old Apr 19, 2007 | 12:25 AM
murdock's Avatar
clk 320
WOW, you must have hammered the living Sheet out of the dust caps?
Thanks for your help.
Old Apr 19, 2007 | 03:19 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
MB centerbore is 66.5.
my question is how did you get the rear two to be hubcentric and the front two not??
Old Apr 19, 2007 | 09:30 AM
derek m's Avatar
Did you try that or ended up returning the rims?
Old Apr 19, 2007 | 12:37 PM
murdock's Avatar
clk 320
The rear ADR's had a bore of 66.56, but the salesman at ADR told me they dont have a 19x8.5 application with 66.56 center bore. I ordered a pair of hubcentric spacers for the front..
Old Apr 19, 2007 | 12:39 PM
murdock's Avatar
clk 320
Still have the wheels...
I'm going to cut, shorten and weld the dust caps or machine some out of 6061 if I have time...
Old Apr 19, 2007 | 04:28 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
yea it was pretty hard to hammer it in...
Old Apr 20, 2007 | 02:07 PM
s.f.clk02's Avatar
CLK320 2002
i have the same rims on my car. wheelworks was saying the same stuff that the front dont fit and the rear ones do. i took it to a different spot and they put them on im a couple of minutes i think they put spacers on just take it to a different shop.
