can a 320 do a burn out ??
Ok, first you put the car in "drive", turn off ESP, close all the windows because the smoke will go into your car and you don't want your interior to smell. Now Step on the brake and don't let go, gas a little, you'll feel the car trying to move but the wheels are locked. Gas more and let go of the brake a little, if the ground is wet (works on dry ground too but spray some water or do it in the morning will help), your rear tires will start spinning and it'll be real foggy soon. Remember to gas more as time goes by but don't hit the red line, and let go the brake a little so the rear wheels will start spinning. Is this clear enough for you? I appolagized if it doesn't. Have fun !
-Bruce
-Bruce
