removing door panel
99 clk320
removing door panel
Hey guys, just bought a pair of new 4" mids to replace my blown speaker in the rear part of the door. I figured out how to take the bottom half of the door off but there seems to be more holding it and i cant find out how it comes apart without breaking it. Does anyone know how the door panel comes off?
2003 clk55
Use a wedge and remove the abs cover theres a screw behind it. Then pop off the front of the door handle theres a space in the bottom where you can fit a smaller wedge or a flat head screw driver with a thick rag on it. Then remove the Tweeter pod with a wedge. Remove the door lock trim cover 1 screw. Then remove the chrome piece at the top of the door when you open it three small phillips screws. then pop all of the clips out of the door and lift up. Remove the wires to the seat adjust and then wire behind the door pull.
99 clk320
Thanks buddy, one more question though. "Then pop off the front of the door handle theres a space in the bottom where you can fit a smaller wedge or a flat head screw driver with a thick rag on it." Is this the long handle or the chrome pull handle? does it just pop off? Is there a screw in behind there?
2003 clk55
The long door handle. The one you pull the door close with. You will see if you look underneath it there will be a small opening. It will take some force to take it apart. Just insert it in the opening and pull the tool towards you and it will pop off, then remove the screw behind it.
