anyone else with this problem???
The ML....if you were getting HOT air before and are getting cooler air now, maybe you just need more refrigerant. As soon as you refilled it, was it ever really cold? If not, is the temp of the air the same after you refilled it and now? IE has it gotten warmer? If not, it's not uncommon to underfill a system that needed recharging. (Thing is, you shouldn't be leaking refrigerant in the first place). You just need the cabling and guages to check. If you do need more, just make sure you use a can with UV dye in it.
I didn't use the uv dye, looked at it when i was at the store, but didn't get it. is #7 the refrigerant level? cuz when i first recharged it was at a 5 and when i checked it today it was at 2.
And one more, if I here the compressor engaging does that mean it still might be bad?
p.s. really appreciate the help. there's so much to learn about my car
so i guess pretty much case closed, its just time to take her into the shop. it was worth a shot. lets just pray it stays cheap
Today I started it from sitting all night, it blew ice cold for the 3 minutes I had it running. I took these pictures after 3 minutes of idling in a garage with the exhaust going out the open door, but the front enclosed in the garage and building up heat under the hood.
I need to find out what the deal is because it is in the 90's here as of this week. I don't want the AC randomly working.
Went to a local MB service and in 1hour the car was ready,he said he changed some kind of relay.I paid only 30euros here.
Sry for my bad English
After changing my driver's seat motor I've been endowed with newfound confidence that I can probably do this myself... and although that's probably a mistake, at least I'd like to try and see...
Hell, even if I can't figure it out I'm just out $50 and I'll take the car to the dealer. But I'd rather try to do this myself first and see how far I can get.
NO HEATER! My A/C blows nice and cold but I have no heat whether I have the dial turned to hot or cold on my 99 ML320.
any ideas on this problem? My Mechanic says the ML temp controls are all electronic so he recommends I replace that entire 3 dial control unit.
rick
