anyone else with this problem???
I just experienced the same problem with my CLK about 2 weeks ago. I thought the a/c needed to be recharged, but it turned out to be more than that. It was a leak.
You do probably have a leak...but here's a few good questions...did you ever try it out before you bought it? Was it cold before? Because if it was cold before and it was only a few months ago then you have a bigger than small leak. I suggest you just waste about $40 - $60 and have it recharged and see how long it takes to come out....if it's quick than get it fixed but if it stays cold for a long time it could have just came out over a long period of time while the car sat where ever it was before you bought it. Or you can just have it service and fixed...but it will be maybe a few hundred dollars.
I know that there was a thread in here once about our a/c units seals going bad if it sits to long without being used. I use mine regularly because I live in LA, CA and you need it if your sitting in traffic with a pimp suit on :
How do you know you have a leak in your system? Is the EC light on? Did you check through the A/C diagnostics to see the freon level? If you did and you do have a leak somewhere, you have to determine where it is. Don't just refill and see how long it goes. Refill with UV dye and FIND the leak. Here's an easy way to diagnose your problem....with the car on, hold the rest button until the AC systems menu pops up. Check the freon level (it will be displayed in bar), as well as the the temp levels of all sensors (especially the evaporater temperature sensor).
Is your EC light on? If no, do you hear the compressor engaging? Do you know what the hell I'm talking about? (sorry couldn't resist). anyhow...I'd be more than willing to help...if you provide more information. Best case scenario, it's just your compressor or condensor/radiator. Pretty cheap/easy fix. Worst case scenario...it's your evaporator....then you have to take apart the dash and it gets me$$y. If it is your evap....make sure they change all of your vacuum elements while they are in there. Don't want one of those to fail after you put it all back together........
P.S. Actually your best case scenario would be that you don't have your EC light on and the problem is just your evap temp sensor. $75 bucks.
P.P.S. Everything I tell you is from personal experience with my own car. I must have fixed EVERYTHING on it thus far. (by myself, mind you) So I'm not just blowing smoke here.....
few weeks ago my EC light was finally went off and its blowing nice cold air.. no more rolling down the window half way pretending that i have AC..
usually if the EC light is on.. that also means theres a leak, something went bad or its out of freon/refridgerant.... if the light is on for awhile.. once the freon/refridgerant is recharged.. the systems needs to be reset...
to find out the problem.. running a dianostic on your car should cost about $80... make sure its not some general mechanic shop.. instead take it to a specialist that deals with benz...
You never answered my question as whether the EC light was on or not before you refilled your system. The fact that you refilled your system and it still doesn't blow cold is a "bad" thing. I assume it's not on anymore since you "refilled". Do this....turn the ignition on (turn the radio off)....then turn the ac on 1 click +. You will hear a "clicking" sound from the front of the car. (this is your compressor engaging) If it doesn't "click" then you may have a problem with your compressor. But first things first, check the values for 5 and 7 and report back.
Ok the EC light was off before I refilled the system. It was holding pressure and not losing anything when the gauge was connected. It doesn't blow hot air anymore but its definitely not cold, still just warm air. I still hear a clicking sound so that must be good. And #5 reads 126 and #7 reads 5.
p.s. i did a little more research and found the list of what the different numbers mean
Bad news is...you refilled a system that didn't need refilling. (for future reference...if the EC light is not on, then you shouldn't be worried about refrigerant). Good news is...you're only showing 5 bar of pressure (which is strange if you didn't have the EC light on and you added more). Regardless, you need a little more. But change the evap temp sensor first! I'll bet that will fix it! If you hear your compressor engaging....I'm almost SURE it will fix it.
IF that is you in the avatar.....I'm sure the boys here won't mind if you make payment in some more recent photos. We can even start a poll on the differnent positions
P.s. sorry guys that isn't me in that picture. I'm not quite that tall. I guess it'll have to remain a mystery on whether I look like her or not. Maybe in the future you all will see me with my car when I post new pics of it up. but for now you'll have to assume I do look like her....
The EC light coming on by itself is not really a good thing....can you toggle it off by hitting the EC button? or do you have to restart the car? (by the way...check the value for #7 tomorrow morning, just in case). When you refilled, did you use UV dye?
the EC light is on when i start the car, but if i turn the car off and just turn the power on then i can turn the light off. but it will come back on about 10 minutes after i've been driving and i can't turn it off when the car is running. So basically its looking like i'm gonna have to take it to the shop.
P.S. Try this....start the car and turn on the AC. DO NOT HIT THE ACC. PEDAL. The air should be cold and stay cold. (granted your compressor is engaging and you have refrigerant) What is your value for #7?
[QUOTE=TresX.
P.S. Try this....start the car and turn on the AC. DO NOT HIT THE ACC. PEDAL. The air should be cold and stay cold. (granted your compressor is engaging and you have refrigerant) [/QUOTE]
Nothing but engine-hot air
I appreciate your help.
On the CLK, I can hear a click and the engine idle drops a bit so I assume the compressor is engaging. I'll try what you said in the morning. What # should the refrigerant level be? Unfortunately the ML does not have climate control, is there another way to detect a faulty sensor? My ODB2 scanner is not detecting anything.
