I'm loving the output compared to the OEM xenons. For the OEM xenons, I used philips 6000k D2R bulbs and for the projectors, I went with a philips 6000k D2S kit.
Based on the pics from hidplanet of depo headlight output, i must say that either depo has improved a lot or i'm just lucky.
Now, I don't bother with my 6000k foglights anymore.
In the future, I would love to do a projector retrofit though with maybe tsx projectors. Gotta confirm the size of projectors that will fit though. The ones for the w210 (e55, rs6 etc.) are too big.
Now, I don't bother with my 6000k foglights anymore.In the future, I would love to do a projector retrofit though with maybe tsx projectors. Gotta confirm the size of projectors that will fit though. The ones for the w210 (e55, rs6 etc.) are too big.
I like the flat cut off much better. I hate the angled cut off. they do appear brighter.
Yah me too. I much prefer the flat cutoff although I would prefer an even flatter cutoff hence the need for a projector retrofit in the future. The OEM lights were rubbish! LOL
The projectors are definitely brighter than the OEM xenons as I'm using D2S bulbs with no coating on it for projectors compared to the D2R bulbs i used to have which are coated to reduce glare and brightness.
very nice cut off and beam pattern
Thanks guys!
ExploreFor those guys who have installed these projectors, is your output more or less the same as mine?
That's great!
Thanks again for the RHD tip.
Is your cutoff a bit off on the left hand side as well?
Originally Posted by gianfranc
That's great! Thanks again for the RHD tip.
I'm only happy you could use the info.
Concerning the cutoff, I'm at the moment having some washers fabricated, because the lenses were to far out into the lamp, and in that way obstructing the adjustment of the light output to a certain point. I will come back with info, as soon they are installed.
Wow sounds great! Can't wait to see the result!
giantfranc
are u using the projectors with the cheese graters? is the black or chrome?
care to share where i could get them at singapore thanks
Did you have FACTORY OEM XENONS Before??? Where the new headlights Plug and Play??? Or did you have halogen headlights with an HID KIT??
Yes I'm using the cheese graters. Chrome version.Originally Posted by doramon
giantfrancare u using the projectors with the cheese graters? is the black or chrome?
You can get them from Benzline. You need the contacts?
Quote:
I had factory xenons before. Yes the new lights are plug and play.Originally Posted by AMGEEZY
Did the new lights or the HID kit make the Bulb warning come on??? Also could you take a few pics of the wiring, I just want to see how youe wired the HID kit. Thanks!!!
Quote:
yes please culd i have the contact thanksOriginally Posted by gianfranc
HAHAHA.....Welcome to the dark side of the Cheese grater....
Quote:
Can you take some pictures of the way the HID kit is hooked up??? THANSK!!!Originally Posted by acb3nz
Quote:
No bulb warning for the HID. Sorry no pics. Try HID Plane they have an instruction that explains the wiring.Originally Posted by AMGEEZY
Quote:
sent you a pmOriginally Posted by doramon
I'm not putting out 6 bones until they have a year on them to see how they age. They look cheaply built.
If they do not leak or turn colors after a year or so I might consider them.
