c32 sc... project starts on the on 08/20/07!!!
i found a complete system(injectors, manifold, sc, and water ic) will bolt on perfectly, change the fuel pump to a 5.0 bar one and then try to tune the bocsh system to adapt if this dosent work i have a piggy back system (SMT6) and need to put a small radiator for the water ic + channel it with the system... but the only problem is that the pulley on the sc pumps out .9 bar i will need to decrease it to .45 or .55 ... need help in this one... shall i change the crank pulley to a smaller one or shall i make a custom bigger pulley for the sc??? any feedback??
You may also want to reach out to the folks in the C32 forum, they do some wild stuff over there.
Good Luck!!!
