Shaking?
Any suggestions??? Greatly appreciate any suggestions!
https://mbworld.org/forums/showthrea...ight=maf+clean
Then it became to a point where the car would almost never respond and everytime I tried to floor the car, it wouldn't respond and it would choke. Once this happened, the car started shaking severely, and kept shaking until I restarted the car.
Everyone thought it was the famous MAF problem, I thought it was too, had my mechanic check it out, the MAF was fine.
It turns out that my left side motor mount was broken. It was all torn up and the fluid in the mount was leaking.
Ideally what happened was that when you pressed on the gas, the engine would go higher than usual, and it would block the maf and would not let enough air to get through and would always cause the car to misfire.
So I would say first check the maf & then the mounts.
But how bad of a shake is it? Like rocking the whole car all around...little rocking here and there? Maybe your running some mods we dont know and the engine just wants to jump out of the engine bay? (jk)
Hmm that's a tough one...never heard of something like that especially when you've already checked the mounts...the MAF...but like prznskillz and droptop208 said, definately check the trans mount maybe?
Also check the Spark Plugs, suprised nobody has mentioned that....maybe one of the Spark Plugs went bad?
