trunk
Old Sep 9, 2007 | 02:53 PM
jn_kofi's Avatar
trunk
my trunk won"t open with the remote. the light of trunk opener is steady on in the car. PLEASE HELP
Old Sep 10, 2007 | 12:37 AM
macclk's Avatar
'02 CLK 320
Then you might have a defective trunk switch on the car. It is situated to the left of the lock mechanism. If you open the trunk, you should be able to see it. Try to disconnect 1 wire and close the trunk. Then try your remote again.
Old Sep 10, 2007 | 03:41 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
i had a problem similiar....my light would constantly be on i thought it was tht switch...was 5$ at dealer replaced it...but still continued...the hinges are loose imma have to tighten everything up...goodluck...
Old Sep 17, 2007 | 01:03 PM
jn_kofi's Avatar
can"t find the trunk switch
Old Sep 17, 2007 | 02:15 PM
lawrdent's Avatar
clk 430 cabriolet
trunk
do you have a convertable? Had/have the same problem....sometimes(rarely) when I use my top, the trunk will not open with remote or inside the car. I would have to redo putting the top down or up and then it works.
Old Sep 18, 2007 | 01:28 AM
jn_kofi's Avatar
i don't have a convertable
Old Sep 18, 2007 | 04:17 PM
CLK3201998's Avatar
Try opening the trunk with the key and close it again. That happened to my car when my ex-girlfriend slammed the trunk and then tried to open it with the remote.
HTH
Old Sep 22, 2007 | 03:28 PM
jn_kofi's Avatar
Help Please !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old Sep 22, 2007 | 03:52 PM
jtbeche's Avatar
02 E55; 99 CLK430 (Sold)
I'm not saying this will work, but have you had someone try and put some pressure on the trunk and then trying to release it again? Takes two people, but could be worth a shot.
