Dash board light bulb failed light
Old Oct 11, 2007 | 07:44 AM
fspider's Avatar
CL 500 (2003 W215). Range Rover Sport. Ferrari 360 spider. Ferrari F355 spider. MV Agusta F4.
I had a bulb failed light on the dash. So i noticed that one of the side lights was not working. So now the bulb is changed all lights are working. But the light is still on. What should i be looking at please guys?? Thanks
Old Oct 11, 2007 | 09:33 AM
gregory13lil's Avatar
2000 CLK430
Make sure that you also check all the lights including the turn signals and dont forget the license plate bulbs (this was where I found my fault). The fault should remove itself automatically as soon as the bulb is replaced.
Greg
Old Oct 11, 2007 | 11:27 AM
blkopalS500's Avatar
1997 W140 Chassis S500 Sedan
Speaking off bulbs...
I've got a '97 S500 and the left side instrument cluster bulb/s is out. Makes it hard to see the gas guage at night. Can anyone tell me what I'm up against trying to find/replace this bulb myself? Can I do this from under the dash or do I have to remove the cluster?
Old Oct 11, 2007 | 11:46 AM
fspider's Avatar
Found the problem this afternoon guys. I checked every bulb again and then saw that the rear side lights have not two but four, two pairs either side. One bulb was not working. So all sorted now thanks.
Old Oct 11, 2007 | 03:29 PM
2000 CLK430
I knew it had to be another bulb out somewhere else...Glad you found it!! My license plate bulb had me mad for a while!!
Greg
