Help need to confirm BAS/ECU connector, PIN heigts different?
00 CLK 430 Cabriolet
Help CLK owners. Could someone do me a favor and look at their BAS/ESP ECU. It is the middle box under the black cover under hood on passenger firewall
There is a green and black 2 wire plug that plugs into the center of the ECU. My ECU has 2 pins, one is taller than the other.
I just need to confirm that the connection does in fact contain two PINs that are different in height. Just trying to rule out that a PIN is damaged and causing the starting problem
thanks!
Jim
thanks!
Jim
