[B]Battery/Trunk ISSUE!!! Please Help[B]
SS Minnow Johnson
let me break it down for the techs or wise benz enthuasist i have 1999 CLK430 and all of sudden the trunk wont open (not with the IR key or the release in the car). wats worse is ive lost the valet hard key. my cars battery is dead. so no power i cant open the door to even address the issue. i can get the door open with a window wedge. but the battery is still in a broken trunk. how do i jump the car to START w/ no access. can i achieve engine turnover from the hood terminals? PUH PUH PUH PLEASE HELP ME...
EVERY form of communication to get ahold of me...
myspace.com/tnb1786
tnb1786@hotmail.com
(216)906-5784 Cell
myspace.com/tnb1786
tnb1786@hotmail.com
(216)906-5784 Cell
If your battery is dead but you can get in the car, pop the hood and there are terminals you can hook at positive to. Then you can pop the trunk. Follow this thread.
http://www.benzworld.org/forums/w208...lp-please.html
There is a thread somewhere I can't seem to find but it tells you how you can get into your trunk if your battery is dead and can't get in.
The closet I found was this...
https://mbworld.org/forums/showthrea...ht=clk+battery
Hope that can aid you a bit, if there are others on here that know the thread, post up more for the guy.
SS Minnow Johnson
If you're battery is dead but you can get in the car, pop the hood and there are terminals you can hook at positive to. Then you can pop the trunk. Follow this thread.
SS Minnow Johnson
If I read your post correctly, you can get into the car. Pop the hood...looking at the engine, on the top right hand side (near the fire wall), there is a plastic cover hiding the + jumper post. When you hook a jumper to it (and - to a ground) you should be able to start car and/or pop the trunk.
I haven't tried this at all - I just saved it - just in case I run into this problem.
It was from a UK forum so the cars are right hand drive so not sure it reverse everything or in the same place?
Sorry
Sorry
SS Minnow Johnson
i appreciate ur efforts and i saved the pdf file. thanx a mill for the help
