Wont Start Turns Off CLK
CLK
so this just happend last week and know it got worse.. The car Starts fist thing in the morning, but after driving it for a while the car just turns off, no bogging no nothing it just turns off.... There after it wont start at all! i have to let it sit werever im stuck at and try minutes or hours later! sucks!
any idea anyone or has anyone else had this problem...\\
thanks!
thanks!
do a search..it's probably your crank position sensor. I had the same issue and after replacing it worked like a champ. You can replace this yourself fairly easy.
CLK
thanks guys ill try that out and update it as soon as i change it out, but as fat as it turning off while its being driven, dose the crank position sensor have anything to do with that , is that another sympton that it has or can that be something else??
CLK
Put in the CPS and it took me a while to find it, its behind the engine on the driver side about half an arm length down tilted at an angle with the screw under the sensor kind like this= (SENSOR)> /. <(SCREW) . anyways car starts no problems yet hasent turned off so thanks guys.
