Question about Spring Pads
Old Apr 8, 2008 | 11:44 AM
rocko's Avatar
06 S55 AMG
Hey guys & gals, what drop can I expect if I changed my spring pads to #1 at the front & #2 at the back while keeping the shock and spring stock for now? CLK 430...also, would you guys happen to know the part numbers for those? Let me know..
p.s. still saving money for H&R's and Bilstein Sports. Can you guys recommend a suspension shop that will switch my pads that won't cost me an arm and a leg? (fremont/newark area...I heard some ppl took their cars to "Wheel Works")
Thank you!
Old Apr 8, 2008 | 12:14 PM
deyainrdy4ds's Avatar
w208
i wouldnt suggest takin apart ur suspension just to swap out spring pads cuz its not gunna make a big difference in drop......jus wait till u have the money for the full suspension and then do it
Old Apr 8, 2008 | 12:39 PM
Chappy's Avatar
AMG
Thank you!
The answer depends on what (number/bump) spring pads you currently have on your car.
There is a complete listing of spring pad part numbers and the thickness of each for the W208 CLKs....just do a search and you'll find the thread(s).
Old Apr 8, 2008 | 12:50 PM
Ghostrider's Avatar
01 CLK 430
+1
There is only a 5mm difference from spring pad to spring pad.
Old Apr 8, 2008 | 01:06 PM
sobtypes@aol.co's Avatar
clk320
Where is the best place to get the spring pads? OEM dealer or is there a online dealer
Old Apr 8, 2008 | 01:22 PM
falls profet's Avatar
http://www.performanceproducts.com/
This is where I got mine, and they're cheaper than the dealer. Ship super fast.
Old Apr 8, 2008 | 01:39 PM
Boosted9603's Avatar
CLK55 AMG
Here is the thread I used to get my part numbers from:
https://mbworld.org/forums/showthrea...ing+pad+number
Old Apr 8, 2008 | 02:48 PM
rocko's Avatar
06 S55 AMG
Thanks for all the help! I think i'm just going to do that..wait for all the parts and then hit everthing all at once. Seems most logical since each pad has a 5mm difference..Right now i can fit 3 fingers in the front and then 2 fingers in the back.LMAO! That didn't sound right. Anyway, thanks again guys
Old Apr 8, 2008 | 03:13 PM
That's how my car sets too, which makes me nervous about getting all the right equipment to do right once. Especially since I have #1 pads in the front and ????? in the rear.
Old Apr 8, 2008 | 10:46 PM
sfclk's Avatar
1999 CLK320
i just removed the #5(21mm) pad and it lowered the car to a 1 finger gap. (bilstein sports)
i plan on removing the rear pads and using the next thinner pad to level the stance. (bilstein sports)
Old Apr 9, 2008 | 07:35 AM
J56BP's Avatar
2002 CLK 430
Originally Posted by Ghostrider
+1
4mm !! 5 diff/front #1(5mm)-#2(9mm)-#3(13mm)-#4(17mm)-#5(21mm)
4 diff/real #1(9mm)-#2(13mm)-#3(17mm)-#4(21mm)
Old Apr 9, 2008 | 11:45 AM
sfclk's Avatar
1999 CLK320
+1
Here's a pic with the front spring pad removed with stock springs, 205/55/16s, and new bilstein sport shocks...
I need to work on the rear. Can anyone guess which pads I have in the rear. The shocks in the rear are still original and I had #5s in front.
Old Apr 10, 2008 | 01:02 PM
Wait, are you saying that the corresponding #s are different for front and back? And are those measurements E class pads or CLK pads?
Old Apr 10, 2008 | 02:30 PM
sfclk's Avatar
1999 CLK320
The front #1 pad is a E class part #.
FWIW, I had #5 front and #3 rear on my 99 clk320.
