6 months still cant find the problem!!! help please
-Maf
-Mounts
-Spark Plugs
-Fuel Filter
-Cleaned the injectors
-Cleaned throttle
But after all that money it still shaked all the time when Im at a red light and I can feel a big loss in performance.
What I noticed is when I put the injector cleaner in the tank the shaking gets less intense.
So I went to my mechanic and did the real injection cleaning and it worked no more shaking but instead of the shaking I had I hugeeee lag when I pressed the throttle , as soon as the lag whent away (after couple miles) the shaking started AGAIN!!!
When I changed the sparkplugs we noticed one of the coils was inflated but I didint change it because a faulty coil would trigger the Check Engine Light.(Right?)
So please help!!!!!
-Maf
-Mounts
-Spark Plugs
-Fuel Filter
-Cleaned throttle
So please help!!!!!
have you tried replacing the O2 sensors? this is a common problem w/ our W208's.
I would say that if you have access to a spare coil pack, replace the one that looked suspicious when you replaced the spark plugs and see if that helps. Then move on to the O2 sensors.
especially given all that you've already changed / replaced. If you have high mileage, maybe you have a failing spark plug wire.The o2 sensor suggestion is a good one.
Do you buy gas at the same place all the time? If so, try a switch.
