Two issues power and heat
I saw there was also a there about overing heating? I'm not sure if my car is overing heating I also want they key things to look at for that. thank you guys.
TO CHECK TO SEE IF BOTH AUXILIARY FANS ARE WORKING DO THIS TEST:
Step 1 - With the car off, insert key and turn ignition to the second position where the lights are lit up on the dash.
Step 2 - Press and hold both "Auto" buttons on the Climate Control unit for approx. 10 seconds and then let go (Try it again at 15 seconds if this test does not work the first time with 10 seconds).
- Both Black Auxiliary Fans should turn on and spin.
If only one fan spins, you may have a problem with the fan itself, the fan relay or a circuit to the fan. The chances that both fans do not spin during this test is very slim as both fans should not break around the same time.
The issue that I had was that the Driver's side Auxiliary Fan was shot and did not spin during the test. The Passenger side auxiliary fan was spinning. So, I swaped out the driver's side fan and viola. Fixed - spins. Comes on at approx. 103 cel and shuts off at 98 cel.
Another tip if your car starts to overheat while driving is to manually turn on the fans by doing Step 2 above while driving - this can save your engine/head gasket. My stealership thought that it was the viscous fan clutch and recommended that I change that, the Fan Relay, Thermostat and flush the coolant and then change the Coolant Sensor if the problem was still there. That easily would have been $600-$800. Morons.
Hope that this helps someone.
