"Engine Oil Sensor" Warning should i not worry?
Old Aug 13, 2008 | 06:13 AM
GiZzO's Avatar
CLK55 / E350 Coupe
I thought it would go away. I read somewhere here on the forums if you rev your car high alot which i do. This sensor might trip out due to pressure.
Dip stick oil level checks out fine. Where is this sensor anyways haven't found much about it in my search.
Old Aug 13, 2008 | 07:44 AM
Chappy's Avatar
AMG
My thinking is this: The engine oil is the life-blood of your hand-built $25,000 engine.
Personally, I would have it checked out by a reputable independent Mercedes-Benz repair facility (that knows AMGs). Could be something very minor....hope so.
Old Aug 13, 2008 | 06:05 PM
Focus on this 1's Avatar
Clk 55 04
if your oil level is ok then its all ok , this sensor in known to fail get it replaced at your next oil change its located in the oil pan I think. Its a cheap part. My car once a while pops out the oil level warning then it goes away
