ABS leaking like crazy
(two weeks ago I noticed it in the driveway and in my garage it smelled like brake fluid. Haven't driven since then)
so I turn on the car step on the brake and sure enough it's leaking but it's not leaking from ANY of the hoses leading to the ABS unit. It's actually leaking from the underside of where the main hardline is hooked up to.
It has a hex bolt that holds this part into the main unit but I'm wondering if it has a gasket or something behind it that is causing this.
Have any of you ever had to deal with this. It seems like I'm going to have to take the whole unit out and inspect it carefully but I'm afraid of getting all this air in the brake system and having to purge the whole system. What's the best way to tackle this situation?
Thanks guys
