HELP Clk 430 stuck in P with BAS ESP ABS warning lights
Old Aug 28, 2015 | 07:18 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Where are you buying the parts? Do you have any codes? Did you spill any liquids into the shifter? Replacing any part that solves an issue temporarily 4 times in a month is excessive. I bought my brake light switch from auto zone for $14 over a year ago and have not had any additional issues. BTW this thread saved the day!!
Old Jun 24, 2016 | 05:00 PM
JGSLLC's Avatar
1999 Mercedes Benz CLK 430
Unhappy My ABS BAS ASR Lights wont go off
I have tried 3 mechanics and they have all hooked up their computers and to no avail. No one can give me an answer why these lights are coming on and why they wont go off. I have tried to unhook the battery and that didn't help. The brakes seem to work fine and the car is running normal. What is my problem?
Old Jul 13, 2019 | 05:11 PM
Michel255820's Avatar
e320 w210 and E500 W211
Originally Posted by Gundo
Did your shifter get wet somehow? Spill a drink or left sunroof open while raining? We need more info to help...
Gundo : just curious,
I have similar problem (Stuck in P) and suspect it could have been spill on central console.
This is for E320 W210 year 2000.
I am looking at replacing the batteriy that is old, and replacing brake pedal sensor,
but reading your comment, I wnder if you can suggest another better solution ?
Thank you for you help
Michel
Old Aug 6, 2019 | 04:42 PM
Bis Bisowski's Avatar
W208 clk230
Michel
Do you have esp/bas warning light?
I had this problem few weeks ago and it was fuse in engine bay. Not one in fuse box, but in the box with the ECU. I
Old Oct 27, 2021 | 11:17 AM
24hourchamp's Avatar
2005 E500 4Matic Wagon 2004 E55 AMG 2005 G500 2005 S500 4Matic
What if replacing stop lamp doesn’t fix the issue?
Originally Posted by ctran4949
BAS ESP ABS can not move out of Park If you got BAS ESP and ABS warning light and can not shift out of Park position. Do this: Press on the brake and have someone check the brake light, if not, the Stoplight switch is bad, remove cover above the brake pedal, press on brake and tap on the switch and see if the cylinder release or not, this will let you move out of Park.
If the Brake or Stoplight switch is bad, the computer won't allow you to shift out of Park because it think you are not press on the brake.
This part is around $20 and 30 minutes to replace.
Replaced stop lamp switch, car still stuck in park with ‘reduced braking power’ message
Old Oct 27, 2021 | 02:56 PM
AMG Boss's Avatar
2002 CLK 55 AMG
Try full steering wheel sweep all the way right then left
Old Oct 28, 2021 | 10:15 AM
  #32
TEAsE550's Avatar
Veteran: Air Force
13 E550 Coupe & 99 C280
My 2000 CLK430 use to do this, but only when it was wet out and I would travel in reverse. I would turn the car off, restart and do the full sweep L to R 3 or 4 times. Turn the car off and re-start. All the warning lights would be gone.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
