trans goes into limp mode
Old Nov 7, 2008 | 08:35 AM
TONYLITTELL's Avatar
2001 clk55 amg
i posted a while back about the problem and a few people suggested a maf and throttle position sensor . looking at things i dont think that is the problem.....under the gas pedal when the pedal is pushed to the floor it will hit some kind of button mounted into the floor. when that button is pressed is when i go into limp mode. Im thinking its maybe some sort of electronic trans kick down switch or something?
any idea of what the problem could be?
Old Nov 8, 2008 | 01:43 AM
MarcusF's Avatar
2002 CLK430
Dump the codes. That may tell you what's wrong.
Old Jan 1, 2010 | 12:15 PM
charlesb's Avatar
CLK430; A190
I have the same problem and cand figure out what the problem is, I pulled the error of the car and it says "pedal value sensor short circuit" car goes into limp mode and CEL comes on after this has happned 3 times.
Old Jan 1, 2010 | 03:14 PM
OPALW208's Avatar
SL55, C63
what is the exact code?? P what? PM me the code and maybe I can direct you in the right direction.
