Tune Up
Old Nov 12, 2008 | 04:20 PM
jasonowens32's Avatar
Clk 320
Tune Up
Does this sound like what I need for a tune up on a Mercedes CLK320? Does the price sound reasonable?
This is “Faith” from Live Help. Below are the lists that you need for Tune UP of your car. I give also the quote number containing the same parts as shown bellow, so that It will be easy for you to see it, rather that putting all the part number in search box.
Part Number Part Name/Description Amount
W0133-1618433 K&N Air Filter
1998 - 2003 Mercedes Benz CLK320 $62.95
W0133-1789640 K&N Oil Filter
1998 - 2005 Mercedes Benz CLK320 $18.95
NG5464 NGK Spark Plug
1998 - 2002 Mercedes Benz CLK320 $8.30 (6) $49.80
W0133-1792333 Bosch Ignition Wire
1998 - 2005 Mercedes Benz CLK320 $12.95(6) $77.70
W0133-1625289 ContiTech Multi Rib Belt
1998 - 2005 Mercedes Benz CLK320 $43.95
W0133-1629302 Febi Acc. Belt Idler Pulley
1998 - 2005 Mercedes Benz CLK320 $19.95
DY89070 Dayco Acc. Belt Tension Pulley
1998 - 2005 Mercedes Benz CLK320 $31.27
043-1039 Beck Arnley Fuel Filter
1998 - 2005 Mercedes Benz CLK320 $91.37
W0133-1632374 OEQ Valve Cover Gasket
W0133-1632508 OEQ Valve Cover Gasket
Sub Total: $435.84
Shipping: $8.50
Handling: $14.28
Tax: $0.00
Order Total: $458.62
Old Nov 12, 2008 | 05:44 PM
ZEEK's Avatar
Yo Momma
why do you need to change everything? Do you HAVE to change everything? change wires and plugs, do not get ngk plugs, get bosch (cheap at autozone, exact benz plugs but cheaper price), also dont get k&n get regular mercedes filters.
Old Nov 12, 2008 | 07:27 PM
clk430convert01's Avatar
2002 CLK55 AMG cabriolet
Agreed. You have to draw the line somewhere between replacing everything and replacing nothing otherwise you'll be doing a full restore of a 2003 Mercedes. $91 for a fuel filter is steep and why all the pulleys ?
Old Nov 13, 2008 | 01:01 AM
MarcusF's Avatar
2002 CLK430
No, it doesn't. It sounds like someone wants you to buy their entire catalog worth of parts. Valve cover gaskets?
A tune up means a lot of things to lot of people. What do you mean tune up? An A service? B service? 2 year service? 3 year service? 4 year/40K service? 4 year/50K service? 5 year/100K mile service? Some combination?
If the plugs are 5 years old or have 100K miles on them, change them. If you ruin the wires because you didn't use a plug boot puller, change the wires too. These are some MB USA recommendations - If the brake fluid is 2 years old, change it. If the coolant is 3 years old, change it. If the engine air filters are 4 years or 60K miles old, change them. If the fuel filter is 4 years or 60K miles old, change it. Every 4 years or 50K miles, check your flex discs and re-torque your steering gear bolts. The FSS will tell you when to change to oil and filter.
In addition, these are my recommendations - ONLY use a fleece oil filter. Change the drive belt every 5 years or 100K miles. Change the coolant every two years rather than three. Change the battery every four years.
What is it that you're trying to do?
Old Nov 13, 2008 | 09:47 AM
Clk 320
When I bought the car, the seller said that he didn’t know if Service "B" was completed. The car read that the next service was Service "A". So, he either changed the button to set it back or he didn’t get the service done. At the time of purchasing the car I had no idea what Service "A" and "B" were so I didn’t ask any more questions. I just assumed it was a maintenance service that I would have to do later on. He gave me all records of the car but there was no record indicating a Service “B” was done. I’m having a lot of vibration issues with the car when it's stop while running. If I put in neutral the vibration almost disappears. Not knowing much about these cars (being a Lexus owner all my life) I didn’t know where to begin besides taking the car to a MB dealership so they can knock my head off.
So, I came to a conclusion that maybe if I just did a tune up that would justify some things. I did a lot of searches on the forum and tried to come up with some ideas from everyone on a tune up. Then I contacted a few websites like the one above and received their recommendation. My main goal is just to get the car running good. It’s paid off and the car has grown on me tremendously. I plan on keeping the car as a weekend car for quite some time. Any advice would help. Thanks.
Here is some background information.
September 06, 1999- Replaced 02 sensor.
June 02, 2002- Service “B” was completed.
June 19, 2007- Replaced crank sensor
Replaced air mass meter
February 6, 2008- Replaced 02 sensor
April 21, 2008- Installed new brakes, pads, sensors, etc.
Alignment
There were many other things I replaced but I don think it would matter because it’s not mechanical. All work above was completed by a MB dealership.
Old Nov 13, 2008 | 12:37 PM
ZEEK's Avatar
Yo Momma
If the previous owner did not get service B done then the car would say so, if he did then the car will say "service C in xxxx miles" For the vibration check motor mounts and MAF sensor. I dont know a lot but marcus is here to the rescue
Old Nov 13, 2008 | 12:47 PM
Clk 320
The car is actually saying Service "A" is next in 3400 miles.
Old Nov 14, 2008 | 01:36 AM
MarcusF's Avatar
2002 CLK430
If it were me, I do the trans fluid, plugs, brake fluid, coolant, engine air filter, fuel filter, and cabin filter. That's not what causing the car to shake, but you’ll know all the maintenance has been done. I think Zeek is right - Mounts or MAF.
Old Nov 14, 2008 | 01:43 AM
sfclk's Avatar
1999 CLK320
first thing i think you should do is definitely drain the atf and replace the atf filter.
then consider replacing the motor mounts after the trans service.
Old Nov 14, 2008 | 09:20 AM
Clk 320
Thanks for everyone's input. Ill keep you posted.
Old Nov 15, 2008 | 03:51 PM
af3465's Avatar
MB CLK 320
cabin filter = Ventilation filter?
Is replacing engine air filter included in the B service? From the MB service menu, B has dust filter replacement. In additional service, it said ventilation filter need to be replaced every 2 years.
Old Nov 26, 2008 | 04:00 PM
Clk 320
Update: It was the "motor mounts" causing the vibration. MB Dealership recommendations:
Motor Mounts (DID AT MB DEALERSHIP)
Valve Cover gaskets (WILL DO SOMEWHERE ELSE)
Intake hoses (WILL DO SOMEWHERE ELSE)
Trans flushed (WILL DO SOMEWHERE ELSE)
Fuel filter (DO MYSELF)
Air filter (DO MYSELF)
Spark plugs and wires (DO MYSELF)
Old Nov 26, 2008 | 10:02 PM
MarcusF's Avatar
2002 CLK430
Per my maintenance booklet, this is a B service:
Interior
  1. Function check
  2. Check warning and indicator lamps, illumination and interior lighting
  3. Check windshield wiper, windshield washer system, headlamp cleaning system
  4. Reset maintenance service counter in instrument cluster
  5. Replace dust filter (not applicable to SL-Class)
  6. Replace combination filter (SL-Class)
  7. Check parking brake (function test only)
Wheels, brakes
  1. Check condition/thickness of front and rear brake discs
  2. Check front and rear brake pads for lining thickness
  3. Check tires for damage and condition
  4. Measure tread depth, record in mm
  5. Correct tire inflation pressure
Underside of Vehicle
  1. Check for major components leakage
  2. Check for chafe marks, line routing, damaged components
  3. Check condition of front axle ball joints and rubber boots
  4. Check condition of mechanical steering components and rubber boots
Engine Compartment
  3. Check and replenish all fluid levels
  4. Change engine oil and filter
  5. Check engine cooling system, antifreeze and corrosion protection
  6. Check brake system
  7. Check power steering
  8. Check Active Body Control
  9. Check windshield washer system
  10. Check and correct battery fluid level
  11. Check battery condition
  12. Check catch, safety catch and hinges on engine hood for proper operation
  13. Check condition of poly V-belt
Trunk
  2. Correct tire inflation pressure in spare tire
Old Nov 30, 2008 | 04:10 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
lol u definately need to go somewhere else if they think ur car uses 6 plugs...
Old Nov 30, 2008 | 04:22 AM
Clk 320
Just noticed that. lol
