Need new AC panel control...
Old Nov 23, 2008 | 04:46 PM
falls profet's Avatar
Does anyone know where to get the box that controls the AC and temp, other than the dealer? Does anyone have one they want to sell?
Old Nov 23, 2008 | 10:46 PM
MarcusF's Avatar
2002 CLK430
BBA Remanufacturing in Taunton, Massachusetts may rebuild your old one. They rebuild just about any other MB electrical part. Give them a call at (866) 573 - 2740, or (508) 822 - 4490 if you're in MA.
Old Nov 24, 2008 | 08:09 AM
gregory13lil's Avatar
2000 CLK430
Found one for you on Ebay:
http://cgi.ebay.com/ebaymotors/MERCE...Q5fAccessories
Old Nov 24, 2008 | 10:33 AM
scottster77's Avatar
CLK320, Honda Ruckus, pinto & BMX
whats the malfunction?
Old Nov 25, 2008 | 06:35 PM
Greg- Thanks for the link.
Scott- everything is fine on it except the "up" button on the fan control won't work. It doesn't "click' anymore. That's the only thing wrong with it.
I wonder if I can just get a new button...
Old Nov 25, 2008 | 07:54 PM
2000 CLK430
No you cant buy a new button by itself..Believe me I tried that a while back until I just ended up buying a used unit on Ebay.
I do have a trick for you to make it work until you replace it..It will work perfectly and all you have to do is sell my iphone that I have upi for sale!
Ok for real now..all you need to do is pull the button thats broken off the panel by using a credit card to pry it off. Once you pull it off you will see that the part that broke was a small plastic tab that "pokes/presses" a button. All I did was grab some hard paper "cardboard like but thin" and I rolled it really small.I then inserted it into the hole in the panel that has the broken tab. Then replace the button and see if it works. You may need to make it longer or shorter to get it just right. If done right you wont even tell that its broken and it will function properly. I rode around for 6 months until someone else told me how to do it.
Greg
