its very simple. flip open the ashtray grab the top part of the wooden console right where it meets the ashtray and just carefully pull it up and back
You need to remove the trim around the shift lever first....but basically you just pull off as above. Careful when you raise it up that you don't pull any of the module connections.
you dont need to remove the trim around the shift lever 1st that will come off with it
Quote:
I have answered your other postOriginally Posted by Stuart Osborne
does anyone know how to change the light behind the left heater controls?
http://www.detali.ru/cat/oem_mb2.asp...SGR=150&SGN=03
thank you
ExploreCurrently Active Users (1)
