2002 CLK430 Comand Serial number
2002 CLK430
Is there a way to get the serial number without pulling the Comand unit out? Is there some type of management interface I can get into that will get me the serial number?
1 Post
02 CLK 430 Coupe
In AM/FM mode, hold down MUTE, 1, and 3 all together for about 10 seconds. This will get you into the special diagnostic menu. I think you can mess up your COMAND in there so be careful.
2002 CLK430
Thank You
So if any one needs to do this, the above directions work. Then you will have to drill down into Version -> FIS -> Serial
Thanks for the quick response. Now all I need is the radio code. I have the serial number of 06006610 . Can anyone pull the radio code?
