fans
fiddlyD
The 'primary' fan will come on when your coolant temp reaches 'xxx' degrees. The 'secondary' fan comes on when your coolant reaches 'xxx' degrees plus 'xxx' degrees -OR- you turn the AC on.
So, if you get in your car and turn the AC on even without the car being at operating temperature = no fans.
If the car is up to operating temperature and kicks the primary on on its own and you turn the AC on = primary and secondary fans should kick on. (in fact, you should be able to watch first fan run and then 2nd kick in with AC).
Again, this is from past experience, but no necessarily with MB.
I can check what my car does if you want me to.
John
