oil change price?? overfilled my clk
Old Jan 16, 2009 | 09:22 PM
gartec's Avatar
2001 clk 430
so i am a dummy and put to much oil in my clk 430. now the reduce light comes on.
how much is a oil change and is it a easy thing for me to syphin out some oil. got to drive to wrk tomm so wondering what i can do with minimul tools. or should i go get a oil change with minimul money?
need help here
L.
Old Jan 17, 2009 | 05:23 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Well it sounds like your are not that used to doing work on the car yourslf, but at least you are attempting it !. You are right to drain the oil as too much oil can damage the engine due to the ecxess pressure. The good news for you is that you will not need any expensive tools to remove some of the oil.
The normal method is to remove the oil by undoing the sump drain plug underneath the engine. If you have a socket or spanner make sure it is the correct size to avoid damaging the nut and undo, making sure you have a tray or something underneath the hole for the oil to drain into. Dont worry if you drain too much as you can always pour some back in the top.
The other method is to use a syphen which can be placed into the dip-stick tube enabling you to drain the oil from the top of the engine.
If you do take it to a garage to get them to do it, it should only take them 10mins so dont get overcharged for what is a very simple job ! Good luck
Old Jan 17, 2009 | 09:49 AM
jajara's Avatar
CLA45 C63 SL63 CLK BS C BS SL600 560SEC 500E
go to the oil lube change or something like that,.Oil change should cost you about 90- to 100 bucks, remember you need Mobil 1 Full synthetic....
Old Jan 17, 2009 | 01:00 PM
A1EK's Avatar
eeermmmm ? I think the problem is he has too much oil and does not need more oil, just needs to get rid of some ??
Old Jan 17, 2009 | 01:18 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
You didnt say how much you over filled or why u put oil in. Were you low on oil and due for a change? Depending on how much you over filled, I would correct BEFORE driving. When you over fill enough to reach the crankshaft, the oil will turn to a milkshake when running the engine. The crankshaft will aerate the oil to the point where it no longer lubricates. If not corrected it's bye bye motor time! I.E. overfill is WAY worse than low oil.
Old Jan 18, 2009 | 12:59 AM
MarcusF's Avatar
2002 CLK430
I use a topsider. If you had one, you could simply vacuum out however much oil you're over. Topsiders are less than $50, and it will pay for itself in future oil changes. An oil change is easy. However, if you dont know what you're doing, paying someone is A LOT less expensive in the long run. My local dealer, Mercedes Benz of Valencia, charges between $70 and $100 for an oil change when it's on sale. The regular rate is $125. Considering an oil change is $70 in parts, it's not a bad deal for those who can't do it themselves.
Old Jan 18, 2009 | 11:16 AM
xmodrelic's Avatar
2kCLK320
When I overfilled I just stopped at the nearest oil change place tossed the guy a 20 to take the extra half quart out. It took 5 mins and the guy was glad to do it. He had a tool to suck it out from the top.
Old Jan 21, 2009 | 11:56 PM
gartec's Avatar
2001 clk 430
i got a oil change everything iscool. have not drivin that far. question is when i do the check through the steering wheel when the car is off. it still says reduce oil level. when i check the dipstick the level is fine. but there is no alert that pops up anymore on the dash while driving. maybe i messed up the sensor from to much oil. has that happened to others?
Old Jan 22, 2009 | 10:36 AM
bobbyjo9's Avatar
Ive had that dash sensor give various readings. It's a nice convenience but still go with the underhood check when your at the pumps to be safe.
Old Jan 22, 2009 | 11:53 AM
sfclk's Avatar
1999 CLK320
Maybe there's still too much oil. Where does the oil come up to on the dipstick?
Old Jan 22, 2009 | 03:34 PM
MarcusF's Avatar
2002 CLK430
If the dipstick reads good, and the dash says otherwise, the oil level sensor may be bad. This is assuming you're checking both at the same time. If the dipstick reads full when cold, and the dash reads overfull only when hot, it may be because 8+ quarts of oil expands a lot when hot. In that case, the car is overfull.
Old Jan 22, 2009 | 07:26 PM
gartec's Avatar
2001 clk 430
its is at little more than half way on the stick when hot. and i checked it when hot
drove all day today and no oil warning popping up.
now i was low on gas quarter tank and the exclamation mark came on the dash and i had loss of power. then after fill up it did it once again. dont know whats up with that. hope my fuel pump isnt going bad
Old Jan 22, 2009 | 07:41 PM
AMGMB's Avatar
1999 Mercedes Benz CLK430
Even i overfilled myn and i also took it to the nearest shop and he took a litlle bit out and light was still on to reduce oil so he took out a lil more and it was fine then.
