Steering dampner
Old Dec 30, 2008 | 11:47 PM
OGCLK320's Avatar
2004 E55 AMG, 2008 G55 AMG
Steering dampner
Have any of you replaced yours? Did you feel a big difference in the tightness of steering after?
Old Dec 31, 2008 | 01:25 PM
gregory13lil's Avatar
2000 CLK430
I replaced mine about a 1.5 years ago and it definitely tightened up the steering feel! They are only about 65-70 bucks so its definitely worth fixing if its going out or leaking.
Greg
Old Dec 31, 2008 | 02:09 PM
OGCLK320's Avatar
i just ordered one! thanks
Old Jan 1, 2009 | 03:59 PM
OPALW208's Avatar
SL55, C63
the install is definitely a DIY. takes about 20 minutes.
Old Jan 1, 2009 | 08:37 PM
OGCLK320's Avatar
does the car need to be on jack stands? do the front wheels need to be fully extended? or can i pull it up on ramps and still be able to remove the damper very easily?
Old Jan 1, 2009 | 09:40 PM
MarcusF's Avatar
2002 CLK430
Using a ramp is fine.
Old Jan 4, 2009 | 08:52 AM
Chappy's Avatar
AMG
The steering damper will help. However, if you're looking for that 'rock solid' feeling check your LCA bushings. Mine were bad in my CLK55 at just 30K miles. I replaced mine with polyurethane bushings (both were only about a hundred bucks).
Extremely sure-footed after this mod.
Old Jan 4, 2009 | 06:27 PM
OGCLK320's Avatar
LCA bushings
I will definitely be checking those out... is this a DIY too? or how hard are they to remove and install new ones?
Old Jan 4, 2009 | 08:06 PM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Care to kindly tell me where i can find those polyurethane bushings? What are the other bushings made out of?
Yeah, the Lower Control Arm bushings are gonna cost you an arm and a leg. Unless you have the proper knowledge and equipment, a mechanic is your best bet. Depending on whether your car is lowered or not, you'll also need the proper bolt kit other than just the bushings. It's actually the LABOR that's gonna kill you. While you're at it, it's very wise to check if you need new ball joints. It's a pain in the *** to have them replaced at different times. it'll be like paying expensive labor TWICE. Oh, by the way, if you're car is lowered, and you're bushings are bad and NEEDS to be replaced, you can't get an alignment. The worn bushings are gonna dis-align it.
The only reason i mentioned this is cause, i just spent $400 parts and labor on replacing my two front wheel bearings. They were completely shot and noisy. The high quality bearings itself cost like $50 per side, the labor is the crazy part. Most reputable shops will charge just under $500 for that type of work. And while my car was up on the rack, they told me that i NEED to get both my ball joints and Lower Control Arm bushings all replaced.
Sorry for the long info, just thought that you might want to know.
Old Jan 4, 2009 | 11:49 PM
sfclk's Avatar
1999 CLK320
I was lucky enough to find a small shop to replace ball joints and poly bushings(thrust) for $300 labor. Parts were $50 for 2 bushings and $20/joint.
Old Jan 5, 2009 | 07:26 AM
Chappy's Avatar
AMG
Read this thread....there are pics on there of the stock CLK55 LCA bushings (the stock bushings are rubber). AFAIK, you can order the bushings off the LPD Auto ebay page.
https://mbworld.org/forums/c36-amg-c...hemselves.html
Link to poly bushings on ebay (there may be other sellers as well - this is where I got them from):
http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
Old Jan 5, 2009 | 07:28 AM
Chappy's Avatar
AMG
I'm not a DIYer....other than detailing. I'm certain the labor charges may be costly.
