clk 430 questions
clk 430
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
ok so i just bought my first MB about a month ago, so the other day i came to a stop and the car started shaking so i tapped the gas and it went away, i was reading some threads and people say its the harmonic balancer? how much does that cost to fix? also it says i got a headlamp defection but all my lights work how do i make that go away?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
CLK 430
ok so i just bought my first MB about a month ago, so the other day i came to a stop and the car started shaking so i tapped the gas and it went away, i was reading some threads and people say its the harmonic balancer? how much does that cost to fix? also it says i got a headlamp defection but all my lights work how do i make that go away?![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
You should check your local MB dealership because I believe the harmonic balancer was a recall. It was on mine.
As for the light error, check all your lights, because it could be any that are out.
clk 430
ok so today i get in the car and the light malfunction is off so i guess problem solved there, but as ar as that wierd issue i had i guess i have to wai till it happens more often to guess again, btw how do i put a picture under my screen name like everyone else?
