CLK320 Intake
That's a similar set up we have on the Crossfire and we saw +8RWHP and +12RWTQ. Basically its the same exact set up, but the MAF is near the TB.
Oh well, there are a lot of people that spend money on their car for looks and personal preference, without any performance gain, and that's perfectly ok in my book. If you only add to a car if it makes it perform better you get bored.
- stock air box with OEM filter
- stock air box with K&N filter (i felt no difference)
- short ram air intake setup
- and the current setup (which i actually notice)
though it might not give "that much" horsepower or torque as far as accurate numbers are concerned, the car definitely feels stronger and picks up faster.
This one is from VRP.
Obviously ours would be one intake tube and not dual. To make this work on our cars I think we would just have to bore out the snorkel hole that our air box connects to.
If you stick with one just in the grille you sacrifice a lot of filter volume.
Believe me we've tried on this motor, single intake with a large filter is the best way to go if you're gonna change it at all.
If you compare the M112 MAF to the M113 MAF, the outer diamater is identical, but the inner volume is larger on the M113. So I tried a M113 MAF body both with a M113 sensor and a M112 sensor. The CLK idles and drives, but the larger MAF caused problems with the transmission shifting gears, at times it wouldn't shift out of gear or shift into neutral from drive. Resetting the ECU or TCU didn't really solve the problem, seems the electronic transmission is tied to more than just the TCU. Went back to the M112 MAF and the transmission went back to normal.
I wasn't able to get the car to shift correctly with the M113 MAF, so I couldn't dyno the two MAF's on the CLK.
Just a FYI to save others from the frustration.
