Help: Dash display disorted
Old Feb 6, 2009 | 01:35 AM
azndragonlord's Avatar
2001 Clk 430
The 2 little display boxes which shows the outside temperature and the other that shows the time is kind of disorted. Mercedes told me i have to replace the whole dash but i think it's just a loose wiring because sometimes it will work. Can anyone help me with this? Is the dash very difficult to remove?
Old Feb 6, 2009 | 08:40 AM
gregory13lil's Avatar
2000 CLK430
This is a VERY common occurence on our W208's. It happened to me a couple years ago as well. There is a how to posted by PANCHO I believe??? In either case the cluster is extremely easy to remove. But, you must have a little know patience actually taking it apart to fix the ribbon cable that causes the issue. Sometimes all that is required is to reseat the ribbon cable. I will try and find that HOW-TO later when I get home from work.
Greg
Old Feb 11, 2009 | 10:47 PM
oheim's Avatar
2001 CLK430 - 2007 S2000
Would love to know how to fix this! I know I can just roll down the window and stick my hand out to see how warm/cold it is, but staring at that mess of lines is about to make me drive into a friggin guardrail!!!
Old Feb 17, 2009 | 02:27 PM
Serndipity's Avatar
2001 CLK320 Cabrio
DIY repair is here.
http://www.benzworld.org/forums/w208...splay-fix.html
