battery died, cold weather?
Old Jan 26, 2003 | 01:24 AM
nubomb's Avatar
I was away for about a month and left my car in a unheated garage. I tried to start it tonight and couldn't even open my doors remotely. Does cold weather kill a battery? It's been below freezing here for about two weeks now. Do you think the battery is damaged or just need to be started?
Old Jan 26, 2003 | 01:29 PM
braincuttermd's Avatar
I did the same over XMas and New years for 2 weeks as well. My CLK is a May 01 model with 15k miles. It had no problems starting up 2 weeks later in an unheated garage while the outside temp was about 20F in Ohio.
How old is your battery?
Old Jan 26, 2003 | 02:18 PM
nubomb's Avatar
My car is a 99, with 19K miles.
Old Jan 26, 2003 | 02:39 PM
RJI's Avatar
RJI
Call the 800 Mercedes road side assistance number for a jump start. If the car is still in the original 4 year warranty period, they should replace the battery for no charge if it is bad. Just don't mention that it had been setting for a month.
Old Jan 26, 2003 | 03:20 PM
Timster's Avatar
2011 GL450
Re: battery died, cold weather?
Cold weather is hard on batteries.
You can do a coulpe of things to help prevent hard starts.
Use a trickle charger when you know your going to be gone for a few days.
Take the battery out and place it somewhere warm (Inside, but not near fire) Place it something to protect the surface your setting the battery on. After it's warmer then re-install it. (Caution you may lose some data, preset Radio stations, Home link, ect...) And then try and start the car.
Best thing is to use a trickle charger.
Or as the others suggested Call MB for road side assistance.
Tim
Old Jan 27, 2003 | 07:26 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Hot weather is also hard on batteries, they don't last more than 2 years.
Old Jan 29, 2003 | 05:08 AM
mikeyclk's Avatar
clk 320
What does a battery cost for a CLK?
Old Jan 30, 2003 | 06:48 AM
CLk BoOst's Avatar
1999 CLk320
for 98 and 99 CLKz, the battery went on recall or something, i got a letter from the dealer telling me to go back and change the battery, they said they will give me a new one, but i have not gone yet...... :p
