99 clk320
Old Mar 16, 2009 | 06:26 PM
Walson's Avatar
mercedes
99 clk320
The car runs hot at idle or in traffiic but cruising runs fine. Never over heats as off yet but I was wondering what direction to go to figure this out. Runs at about the 3 quater mark on the temp gauge and I know thats not right. Weather has been cool here in NY just worrying about when it gets hot here. So if anyone has any info please let me know thanks....
Old Mar 16, 2009 | 06:57 PM
joeljp's Avatar
2012 C63
Any blown fuse? It could also be some fans not working right.
Old Mar 16, 2009 | 07:54 PM
Walson's Avatar
mercedes
thanks for the fast reply joeljp there are no blown fuses and there is only one fan and it appears to be working
Old Mar 17, 2009 | 01:55 AM
OGCLK320's Avatar
2004 E55 AMG, 2008 G55 AMG
try the coolant? My car was running a little hot and it turned out to be there was too much water and not enough coolant in my reservoir. you could just need to replace coolant.. its supposed to be a 50/50 mix of coolant and water i believe.
Old Mar 17, 2009 | 02:03 AM
sfclk's Avatar
1999 CLK320
at times, the needle goes right under the 3/4 mark also. does your touch the 3/4 mark?
Old Mar 17, 2009 | 07:44 AM
Thunderdome66's Avatar
99 CLK 430, 84 v8 rx7, 97 gtp grand prix
sounds like water pump problem or possibly thermostat not opening properly if you havn,t done thermostat for a while I,d start their
Old Mar 17, 2009 | 02:45 PM
Walson's Avatar
mercedes
it touches the 3/4 mark then ill start to cruise and it goes back to normal
Old Mar 23, 2009 | 12:07 PM
Walson's Avatar
mercedes
Not quite.
Old Mar 23, 2009 | 12:08 PM
Walson's Avatar
mercedes
Thermostat is new. Haven't replaced the water pump
Old Mar 23, 2009 | 01:30 PM
sfclk's Avatar
1999 CLK320
sounds fine to me.
for my car...driving around the city, the needle gets close to the 3/4 mark. around the highway it stays just over the 1/2 mark.
Old Mar 24, 2009 | 01:04 PM
99CLK320lover's Avatar
CLK320
mine does the same. I was concerned for a while, so I changed the coolant. Nothing changed. Does your fender mounted pump (near the alternator) start clicking when it gets to the 3/4 mark?
Old Mar 24, 2009 | 03:26 PM
sfclk's Avatar
1999 CLK320
...the auxiliary pump, I think it's called. The hose along the chassis pulsates like a heart at all times.
Since cooling hasn't been an problem, I never thought anything of the pulsating hose.
Old Mar 25, 2009 | 11:43 AM
CLK320
Don't fret dude! Mine does the same and I was just curious? I think you're (we're) okay...
