I need springs, shocks and camber links for the CLK 430
I need springs, shocks and camber links for the CLK 430. I don’t want to get crazy or lower the car. What do I want and who do I buy them from?
Thank You.
Thank You.
I would (and have, thanks to Chappy) get the OE CLK55 springs.
If you're going to buy them at a dealer:
I'd buy Bilstein shocks to replace the orignials.
I hope that helps.
- 2103213204 is OE CLK55 front spring. $135 each ($102 w/MBCA discount)
- 2103213204 is the CLK430 front spring. $90 each ($68 w/MBCA discount)
- 2023241704 is the CLK430 (and C55) rear spring. $78 each ($60 w/MBCA discount).
- 2083240204 used to be the part number for the CLK55 rear spring. I think it's been replaced by either 2083240104 or 2083240304 (both the same price as 2083240004), but you dealer can tell you for sure.
I hope that helps.
i have original front/rear clk55 springs if you'd like to buy them. They're in good shape. Factory setup is CLK55 springs and bilstein HD shocks. It's barelyl any lower than stock, but higher performance. PM me if you'd like.
2002 CLK 430
