Steering Wheel Shake
Old Apr 22, 2009 | 08:17 PM
Ghostrider's Avatar
01 CLK 430
No, its not a new dance!!! Its what you feel in your hands at and around 60 mph. I've replaced the Wheel Bearings, Lower Ball Joints, had a wheel fixed, new tires, rotated, balanced and road forced everything I could and....
ITS STILL THERE!!!!!!!
I have some questions for those with this problem:
What can anyone tell me about replacing the Upper Ball Joints and the Lower Control Arm Bushings?
Anyone had this done?
Does anyone make aftermarket bushings for the W208 chassis?
Anything that I'm not asking but should??
Thanks for your time...
-Ghost
Old Apr 23, 2009 | 12:36 AM
MarcusF's Avatar
2002 CLK430
How old is the steering damper?
Old Apr 23, 2009 | 01:21 AM
sfclk's Avatar
1999 CLK320
Drag link
I got mine from Mercedesparts . Com
And yes there are urethane thrust bushings.
Old Apr 23, 2009 | 01:41 AM
ahmed18881's Avatar
frankenstein 2001 CLK 430
Originally Posted by sfclk
Drag link
from where do we get a urethane kit for the car? what is available? off the shelf of custom order?
Old Apr 23, 2009 | 01:56 AM
thebender's Avatar
White 1999 CLKL320
I bought these poly LCA bushings for my W208 $94.98 shipped on eBay! I had a shimmy between 40-70 but varied based on the road surface. Last year I replaced my tie rod assembly (drag link) and steering damper which helped reduce the sloppy feeling in the steering, but the shimmy was still there. Last weekend I did the drivers side lower ball joint and LCA bushing. The old ball joint was sloppy and the LCA bushing rubber was cracked. I will finish the passenger side this weekend. I should have a full writeup of how to replace the LCA bushings & ball joints in the next few weeks. The job is not for the faint of heart, but neither is shelling out 4 figures to the dealership. Hopefully all this work will make the shimmy a thing of the past.
Old Apr 23, 2009 | 07:37 AM
Chappy's Avatar
AMG
It should....the LCA bushings worked for me!
Old Apr 23, 2009 | 02:50 PM
Ghostrider's Avatar
01 CLK 430
Thanks Marcus, I forgot to add that on the list of things that had been replaced.
Old Apr 23, 2009 | 03:40 PM
Ghostrider's Avatar
01 CLK 430
One side was replaced about a year ago.
Drag link
Old Apr 23, 2009 | 07:27 PM
Ghostrider's Avatar
01 CLK 430
bender...
Thanks for the heads up!!! I just ordered mine and will keep my fingers crossed.
Old Apr 23, 2009 | 09:06 PM
thebender's Avatar
White 1999 CLKL320
Ghostrider let me know if you are changing them yourself. I may be able to help you out. I ended up making a tool to remove the bushings. I would never have been able to do the job without it.
Old Apr 24, 2009 | 02:21 PM
Ghostrider's Avatar
01 CLK 430
I do appreciate the other, but the last time I worked on my car I had to have it towed to the dealer....
