Clk430 rear diff oil change
Old May 23, 2009 | 12:47 PM
tastoto's Avatar
ck430 2002
How many litres of oil does the rear diff take on a clk430
Old May 24, 2009 | 12:27 AM
hope's Avatar
1998 ML 320, 2001 C 240, 2002 CLK 320
About 1.5L, you fill up until it start to flow out of the fill hole.
Old May 25, 2009 | 08:37 PM
wnycec's Avatar
2000 CLK 430
How do you fill it up and how do you drain it?
Old May 25, 2009 | 09:54 PM
MarcusF's Avatar
2002 CLK430
On the lower passenger side of the diff, there is an oil drain screw (6 point, female hex, impossible to miss). Per the WIS, take it off and throw it away. While the oil is draining clean the new oil drain screw and put a little sealant on the threads. When you're done, do the same with the new oil filler plug. With the diff empty, clean the threads on the drain hole and install the new drain screw. Move to the driver's side of the diff there's an oil filler screw that sits a little higher. Yes, that one gets thrown away too. Add 1.1 liters, clean the threads on the filler hole, and install the filler screw. Both the drain and filler screw should be torqued to 50 nM (37 lb/ft).
Some people reuse their drain/fill screws. They're part number 0009976232, and cost $2 each.
Old May 26, 2009 | 11:20 PM
thebender's Avatar
White 1999 CLKL320
What kind of gear oil are you all using? As far as I know all you need is the correct weight and a synthetic oil. Can anyone confirm this?
Old May 29, 2009 | 04:58 AM
tastoto's Avatar
ck430 2002
lucas gear oil 80w90 should be fine
