KMAC CAMBER KIT AND KONI ADJUSTABLE SHOCKS
OK I ALREADY POSTED THIS AT THE OTHER BENZ FORUM AND I JUST COPIED AND PASTED AND I NEED HELP PLEASE. THANK U
Hello ladies and germs:
I drive a CLK 320 cabriolet 2001.
its sitting on 19's and progressive HR sport and took #1 pad from E class.
I WILL PROVIDE PICS ONCE THE WEATHER IS NICE.
I wanted to remove the pads to make it lower like CLKFAN but i could not do it, it rubbed and once my camber kit got installed, its brought my tires close to the fender and rub lil from left side.
the results were this:
im happy from my rear camber but i dont think the front did much.. i dunno.. WHAT DO U ALL THINK?? I REALLY NEED A FEEDBACK...
First i used to get like 8000 miles on my new tires but now the shop told me i should hit 18000 and if i rotate the tires it will be 22000..i hope they are right.
Results were:
FRONT LEFT
ACTUAL BEFORE SPECIFIED RANGE
-2.3 - 2.2 -1.3 -0.6 CAMBER
5.5 5.7 5.0 6.0 CASTER
0.19 1.51 0.12 0.29 TOE
FRONT RIGHT
-2.0 -2.7 -1.3 -0.6 camber
6.3 7.5 5.7 6.7 caster
0.20 1.52 0.12 0.29 toe
REAR LEFT
-1.7 -2.1 -1.7 -0.7 CAMBER
0.39 -1.13 0.03 0.53 TOE
REAR RIGHT
-1.7 -2.7 -1.7 -0.7 CAMBER
0.19 1.06 0.03 0.53 TOE
im guessing the green is that im doing good within the range that im suppose to be at and the red is bad..correct?
HOW CAN I GET THE FRONT FIXED? SOME SAID TO ME TO GET BOLTS FROM THE DEALER?? IM LOST
Results were:
FRONT LEFT
FRONT RIGHT
REAR LEFT
REAR RIGHT
NOT TO MENTION LABOR WAS $552 (GAVE ME A DISCOUNT AND I WAS HONEST TO HIM AND TOLD HIM I DONT MAKE THAT MUCH, HE SAVED ME $250)AND ALIGNMENT $225 AT A DIFFERENT SHOP SINCE I HAVE 19
RIDICULOUS
AND THE BUSHING SQUEAKS ON AND OFF WHEN U ARE DRIVING SLOW AND OVER A BUMP.. I GUESS SINCE THEY ARE POLY BUSHING
RIDICULOUS
RIDICULOUS
RIDICULOUS
I had oem camber bolts installed for more negative and I'm sure you can get them installed for less negative camber by pushing the arms in with the bolts. They're only about $60 for the 4 sets you'll need.
From looking at the pictures of your car, the reason it didn't change much is because the car sits so close to the wheel itself.
im looking into it...
I don't think you will be able to get it fully in spec. You should also reach out to CLKFan to see what he did on his ride.
I know i cant fully in spec, but i want it as close as i can , better than nothing.
it did not even change a degree (front)..sucks
2000 CLK 430
Results were:
FRONT LEFT
FRONT RIGHT
REAR LEFT
REAR RIGHT
Results were:
FRONT LEFT
FRONT RIGHT
REAR LEFT
REAR RIGHT
So I guess based on this post, we could have our caster adjusted on the front wheels? I took my car in for an alignment yesterday and the guy told me that he couldnt adjust my caster. I have a slight tilt of the steering wheel to the right. He measured my rear wheel base to front wheel base and it was off by a quarter inch. This could be fixed by a legitimate shop right?
they could not grease mine since it has a metal between the bolt and the bushing..they sprayed em with some type of oil and its much better
what do u mean by the wheel base? im lost
no bro not at all. my front left side went -.02 and right front gain.01.. in other word it was waste. been talkin to simon from evo and said i need to remove my k mac front kit and gets new bushing and a camber bolt from clk 55 and should help lil.
2000 CLK 430
As for my comment, I was just repeating what he told me. Imagine a tangent line runing vertical from the front of the back tire to the back of the front tire - please excuse my weak illustration
O = Tire
|------| = distance he measured
O|---------|O
and told me that this measurement on each side of the car was off by a quarter inch or so. So essentially, if both rear wheels are aligned perfectly then the two front wheels were not aligned perfectly. One was slightly ahead of the other.
Any help would be great. Right now my steering wheel is slightly to the right.
I went to a local shop where I buy my rims from. The guy doesnt really work on mercedes.
O = Tire
O|---------|O
O = Tire
O|---------|O
