Dynomode on our w208's?
Has anyone gotten there w208 into dynomode? I tried to do it but I cant get, I followed the universal directions to do it. I cant even get to the screen that lets me see the battery voltage.
1. Insert your key and turn to position 1.
2. Press the trip odometer reset button three (3) times.
3. The first screen you will see on the MFD is the battery voltage in the following format - UB: 12.0 V
4. Press the UP arrow button on the steering wheel.
5. You will now see other information such as Software Version, etc. If you turn the key to position 2 you will get a oil reading by QTS and other info will appear.
6. If you want to put the car into DYNO mode which will disable ESP and BAS, leave the key in position 1 and hit the up arrow until you see the screen that says "ESP Dynamometer Test".
7. At this screen use your + or - steering wheel button to turn this mode ON.
8. You will get some malfunctions due to ESP, BAS, etc. being off, but this is not a problem and they will go away once you disable the DYNO mode.
9. You can start you car now to DYNO it without all the electronic wizardry getting in the way.
CAUTION: DO NOT DRIVE LIKE THIS OR BAD THINGS MAY HAPPEN. ESP, BAS, ABS are desirable when driving
10. To exit out of DYNO mode, simply turn your car off then back on and it will reset to normal.
