Replacing cabin air filter (correct part?)
Old Jul 16, 2009 | 07:04 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Microair makes the cabin air filter.
Looked at the dealer repair order (the last time it was changed) and the MB part number they used was 2108300818.
However, there is a 2108300818 (w/o activated charcoal) and 2108300818 E (with activated charcoal).....see below. Note: the dealer P/N did not have the 'E' appended.
http://www.autohausaz.com/search/pro...ollen%20Filter
Autohaus said they are physically different.
I've done a bit of homework and believe I need the one with the activated charcoal.
Can anyone confirm?
TIA,
Ed
2001, CLK320 Cabriolet
Old Jul 17, 2009 | 12:54 AM
MarcusF's Avatar
2002 CLK430
Either one will work. I always use the charcoal (and ignore the smell until it clears up in a day or two).
Old Jul 17, 2009 | 10:17 PM
Aaron68's Avatar
2005 CLK55 COUPE
I replaced mine last weekend which I bought from Autohausz.com.
I got the Bosch PN: C3870 which is charcoal one, for like $17.00 or so. It seems to be great. I do not even recall it to smell at all. Changing it was like 5-10 mins tops. I also bought valve cover gaskets from them which I have not installed yet.. Its just been to hot here :-)
Cheers!
Old Jul 18, 2009 | 07:04 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Thanks all.
BTW, the Bosch filter is a deal but it's on back order and they don't know when it will be back in stock.
I ordered the Micronair w/ charcoal cabin filter, PN 2108300818OE (about $7 more). This is the same Mercedes PN that my dealer has used. Also ordered a wiper blade refill which also had the same Mercedes OEM PN....of course, all for a whole lot less money. One caution on using the wiper blade refills.....make sure the blade is still the orginal factory unit (otherwise they said that is would not fit properly).
The following link has pictures of how to install a cabin air filter.
http://www.panchogun.com/FVWebPhotos...bin-Filter.jpg
Old Aug 1, 2009 | 08:47 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Arron68
You're a better man than I......took me one hour (getting the cover and white locks back on cabin filter bay was troublesome).
Old Aug 1, 2009 | 08:55 PM
clk430convert01's Avatar
2002 CLK55 AMG cabriolet
I got the OEM cabin air filter at the dealership today. $50 after MBCA discount. Don't know if its the charcoal variety but smells fresh bros.....
Old Aug 3, 2009 | 08:55 PM
Aaron68's Avatar
2005 CLK55 COUPE
Originally Posted by Serndipity
Arron68
Maybe I got lucky..
Old Apr 23, 2011 | 01:16 PM
McGary911's Avatar
2000 CLK 430
Arron68
You're not kidding! I was about an hour in, and making no progress with the clip closest to the firewall.
I ended up shaving off the little nibs and was able to get it on from the other direction, center toward the edge, rather than edge to center. It still wasn't fun.
Old Dec 28, 2011 | 08:17 AM
fullmetaljacket's Avatar
CLK 230 KOMPRESSOR
Sorry to resurrect an old thread guys but it's better than starting a new one.
Will cleaning or replacing the CABIN FILTERS increase the strength of the air coming out of my vents? My problem is even if my fan speed is on MAX (position #5 on my rotary selector switch), The air coming out of the AC vents feels like it's only #2 or #3 strength/speed Any other thing I have to clean? TIA!
Old Dec 28, 2011 | 12:20 PM
MarcusF's Avatar
2002 CLK430
I doubt it. As a test, remove the filter, close it back up, and then put the fan on MAX. If it still comes out slowly, it may be the regulator. That's an easy job. However, your car has rotary dials so it may differ.
Old Dec 29, 2011 | 10:38 AM
CLK 230 KOMPRESSOR
Is the regulator you are referring to the same function as the BMW FSR Final Stage Resistor? I replaced/DIyd my X5 FSR last month. They look the same - mini aluminum tubes sticking out. I will do the regulator and the filters right after new year. I hope these parts are not too expensive. Thanks Marcus!
Found another DIY article on this regulator that might help others who need more pictures...
Old Dec 31, 2011 | 01:11 AM
Pancho's Avatar
2000 CLK430 Cabriolet
Nice to see folks using my instructionals. Encouraging.
Old Jan 1, 2012 | 09:07 AM
CLK 230 KOMPRESSOR
Thanks to guys like marcus and pancho for unselfishly sharing your knowledge and experiences FOC to the community! As they say...you are gentlemen and scholars! Happy new year- cheers!
Oh by the way, when I open the panel to access and clean the filter, the blower motor resistor/regulator is already there at arms reach so do you suggest I replace this as well? I read through the threads concerning regulator malfunction and the symptoms are all about sporadic, erratic and fickle fan speeds rather than the strength of the airflow which I am experiencing.
How do I make sure that this regulator/resistor needs to be changed already? I don't want to purchase this part just to test if its ok or not then alter you find out that everything's the same. Is there another test?
Old Jan 1, 2012 | 10:58 AM
Pancho's Avatar
Thanks for the good words. Nice way to start a new year.
You can do an A/B test comparing performance of the blower with the regulator and without regulator. I haven't removed the blower, but I seem to recall Marcus having mentioned this testing scheme in a previous post.
First, get a good idea of how the blower is behaving, ie. remove the passenger footwell cover to expose the regulator and blower, and listen/observe and remember the speed/sound at which it turns with fan speed set to highest level. Remove regulator, and remove blower. with alligator leads, connect blower by itself to your car battery, and compare its speed to what it did when installed in-line with the regulator. If blower runs well, then problem is probably with the regulator. If blower runs sporadic, slow, badly, then problem is probably with the blower.
PS. My blower is sporadic (Never been replaced, so it's now 12 yrs. old.) and I'll probably be doing this when I get time, about February.
Old Jan 1, 2012 | 06:59 PM
Flounder's Avatar
'99 CLK430
It definitely made a noticeable difference for me.
I just changed mine today with a Wix w/charcoal (24767). I just bought the car a few weeks ago and I don't know if it was ever replaced; there were leaves n sh*t.
Old Jul 23, 2013 | 03:52 PM
fd3's Avatar
fd3
2002 CLK55 AMG 2002 c230k 02 Triumph America 1992 300e
you're instructional pics are great man, Thank you
Old Jul 23, 2013 | 06:49 PM
Pancho's Avatar
You are most welcomed.
